Refinishing the Teak
Mar 31, 2012
139
Nord Cantieri 38 St Marys
" I can't believe Teak on a boat is so difficult considering how much it is used!!!"
The people building boats know what materials to use to maximize the industry's service income long after the boat is built. :)
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
I am in Stu Jackson's camp. If you want your external teak to have a surface like a dining room table, and unless you cover all expose teak after each sail, be prepared to spend hours each season sanding to fresh wood, masking with tape, and then applying several coats of "what ever" finish which only lasts a season or two before the whole process must be repeated.
If quick maintenance, but less than dining room appearance is OK, then the best thing to do with teak is sand off all varnish type coatings. Then just wipe with teak oil every season. Yes, it will look gray and weathered after the first year or so. But it will look the same 10 years later!
I did away with a lot of the exterior teak on my boat. The grab rails were replaced with SS and my cabin top teak "eye brow" is gone.
The teak that remains (companion-way frame and ornamental pads under the primary winches) is now painted with Rustolem's Hammered finished. This paint is metallic looking. Maintains it's near original appearance on teak for a few seasons. Eventually it does begin to wear/crack. But then it's a quick job to sand off the loose spots with very rough sandpaper and put on a new coat over. No need to sand back to bare wood as required if doing varnish type bright-work.
that looks good ...you do know they have a bronze copper color in that if you feel the need to assimilate the teak look
Jul 3, 2016
6
Morgan 34 Morgan 34 Sloop Ladds Landing
There is some that I can definitely keep the teak around the cockpit can be salvaged but the floor of the cockpit is bubbling and the gangway I accidentally hit with a pressure washer and blew off some of the teak. The boat is so solid though A I took it out twice today. This morning was a ton of pressure and had the full jib up - not a creek or worry about the jib sheet gunnel pulleys that are on the outer teak. Some of the teak is fine. I was just an idiot ant got too close to the gangway hatch with a pressure washer - so anyone has a suggestion about where to buy teak that would be huge!
Jul 3, 2016
6
Not for nothing I am shocked at how well preserved my teak is wu h no finish on it or ever was. This thing was in Bermuda as a charter boat then in the great South Bay for ten years now in VT for 30 year the teak is shockingly in tacked. Actually if it wasn't for my father so staunchly against painting or urithaning I would have done it years ago- but I am now becoming a believer. This stuff will last with no intervention!
