just finished refitting....
my reefing system. i tried getting around drilling the rivets, but, to get the blocks that i wanted in there, i had to. discovered that it is all in the blocks and the quality of the line. the line for the deep reef didn't look to bad so i tried to re-use it. replaced both blocks with 2 each 2" ball bearing single blocks shackled together, and replaced the shallow reefing line. when finished i could pull the shallow reef out of the outboard end of the boom with two fingers. the older deep reef i had to use a fist and a fair amount of muscle (which was an improvement considering that before i had to run back and forth between ends of the boom, pulling line from the cockpit inboard, then pulling the slack outboard). after replacing the deep reefing line, they both now feed from the cockpit to the end of the boom effortlessly.thanks for the tip on the blocks alan, the originals were indeed crap
