Reefing: Procedural Questions
duck21
Jul 17, 2020
197
Hunter 376 0 Washburn, WI on Lake Superior
Hi all,
While we get out and sail pretty regularly, the Admiral (and our dogs) sometimes get a little nervous around higher winds, so we tend to be more fair weather and/or choose to motor. Not that we CAN'T operate the boat should bad weather come up, we just typically choose not to (given that we mostly cruise in a fairly secluded set of islands within 30 miles of our main port choosing to motor in rougher weather isn't a hard choice). This is a long way of saying, while I'm practiced at reefing, we don't actually sail under reef very often.
We have a single line reefing system -- a set of blocks at the mast that hauls the sail down with the line running through the boom that pulls the leech down and tensions to form the foot. Pretty straight forward, all doable from the cockpit. We have a Dutchman system, so presumably the excess sail is held in place by the filaments. This is also what leads to my questions:
When reefed do most folks rely on their sail flaking system (Dutchman, Lazy Jacks) to hold the flaked sail in place, or do you typically use sail ties/lines to lash the excess sail to the boom (I'm asking mostly of coastal/island cruisers -- I think tying off the excess sail would always make sense if you're going to be sailing in higher winds for many hours/days at a time while on an extended passage)?
If you do tie off the sail, how do you go about that -- do you try to do so while the sail is under power (which could be tricky, walking on the coach roof in an upwind sail while the boat heels), or do you do this while the sail is luffing (which, in my experience, can be quite violent in a relatively high wind situation)? If the latter, do you just keep the boom centered and the bow pointed into the wind? (I'll note, we do have grommets in our sail, so tying things down IS an option, I'm just not sure how to totally go about it).
Yesterday I ignored a few Admiral/pet protests and we did do some reefed sailing (winds were 15 to 20, gusting to 25). I raised the main with the reef in place, but I did not go on top to tie things off. I considered tying things off, but wasn't comfortable going up top with the sail luffing. I thought about heaving to, but in doing so, with the main sheet fully released, I can't reach the majority of the boom from the deck (so tying off becomes quite difficult). I ended up sailing just relying on the Dutchman, although pointing upwind was difficult as the sail shape wasn't great. Also, one of the Dutchman filament cars popped off the topping lift, so we had a bit of sail flopping around (this may have been more of a filament tensioning issue, though, not exclusively because we were reefed).
The sailing was fine, although eventually I was convinced to put the sail away and we had a nice (mostly up wind) motor back to port.
Curious as to others thoughts/procedures.
Thanks!
Doug
7,569
Alden 50 Sarasota, Florida
Dutchman lines aren’t designed to and won’t hold a sail in a blow regardless of tension. That’s why it’s necessary to tie off. You should be able to safely reach at least one or two sections of the boom without acrobatics depending on the size/shape of your dodger/bimini.
Likes: JoeWhite
duck21
Jul 17, 2020
197
That makes sense (and aligns with my experience). I may try tying some "permanent" tie offs on the grommets then practice reefing (and tying) in lighter winds. I wouldn't mind sailing more in heavier winds, although I need to get the crew accustomed bit by bit.
May 1, 2011
5,209
Pearson 37 Lusby MD
I let my sailpack contain the reefed main. If I knew I'd be maintaining the reef for an extended period, I'd consider putting a sailtie or two through the grommets in the main. If it's really blowing stink, I'd have no problem with motoring into the wind to add the sailties.
Oct 26, 2008
6,346
Catalina 320 Barnegat, NJ
I have the same set-up as you do with single-line reefing and a dutchman system. Don's right that a dutchman system isn't intended to take the strain that may result from reefing; however, I don't think the dutchman needs to or should take any strain even when you don't tie off. I always slack my dutchman before raising the main anyway. I only tension it again when readying to drop the main fully. BTW, I've never had to replace the filaments yet in 4 seasons going on 5.
I never tie off the loose folds and don't have grommets anyway. That said, I only have a single reef and don't have double reef points. I reef frequently and have found that the single reefing system is more difficult to get the sail shape done well. My previous boat had lines for the leech only and ram's horns for the tack. I found that system better for sail shape. But we have to deal with what we have. I find that the shape improves when I don't try to draw the tack as close as possible to the boom. The clew never gets quite close enough and the shape is distorted if you try to draw the tack down too tightly. @Ward H taught me this idiosyncrasy. I try to draw it down just snug enough to the point where the clew can't get any tighter and the tack matches the height of the clew.
I'll suggest that you do not have to bother tying off the folds. They hang relatively undisturbed when you are on a single-reef. I found the double reefed sail could use some tidying up on my previous boat, but not even necessary when sailing shorter time periods. It sounds like you want to do more sailing under single reef point but you aren't going to sail when needing the double reef. I would slack the dutchman and not worry about tying off the sail. When I mean slack, I'm not talking about slacking to the point that the filaments are flopping around (that just allows chaffing). Just slack enough to relieve the tension so the filaments can move with the sail without any resistance.
You are right ... there is no easy way to tie off the loose sail material in rough conditions. I think there is no reason why you should think that you have to.
Likes: Ward H
Mar 6, 2008
1,400
Reefing is performed before the wind picks up. Learning the weather is the key. I do not tie the excess sail as the sail may become torn. Ask me how I know. As noted above the Dutchman reefing lines will not keep the sail from falling off the boom. Check the cars, they should not fall off the topping line. The line should be 1/4" thick.
I don't think you are supposed to tie the buntlines around the boom - I don't know why. On my Mark 25, which had a Dutchman system and a foot that was in the boom channel. I did not tie the buntlines because they would have to go around the boom. I would let the first reef excess sail hang.
I had trouble setting up single line reefing on my Ranger. I think getting the tension right at the clew and tack is a challenge. I think that's because the distance the clew reef line has to come in is different than the distance the tack reef line has to come down That was a loose footed main and I did tie the lines I could reach - sometime on the cabin top. It's not that scary because you go up on the high side and would fall into the sail if you lost footing.
Regarding your Admiral/Pet problem, I would go out in mild weather with the reef tied in - with good sail shape. Then shake it out if necessary. But if a bit more wind comes up you will find that sailing with a reef makes a much calmer situation which both Admiral and Pet will appreciate. The heel will be less, the helm more balanced and the sail trim easier. In short - more fun.
Likes: Ward H
duck21
Jul 17, 2020
197
Indeed, the islands we sail in/around often have a wind tunnel effect -- but it's also not necessarily consistent. Our reefing is usually less "incoming weather" and more "rounded the point and oh my, wind switched to the East and jumped up by 10 kts."
Although, with yesterday's experience we motored out of our anchorage and into the channel, at which point I decided to try sailing. I deployed the sail with the reef from the beginning, but by then was already in the wind and the chop. I decided not to exit the cockpit to tie things down, but that got me thinking as to how best to proceed, hence this thread.
BTW, thanks to everyone for the insights and comments!
Doug
in an ideal world.
I suspect we’ve all be surprised by conditions we didn’t/couldnt anticipate and i infer that prompted the OP to solicit opinions.
duck21
Jul 17, 2020
197
Hi Scott,
Thanks for this insight -- beyond the flopping sail and car that came off (again, maybe not specifically a reefing problem -- more on that later) I was also struggling with sail shape, which is also what got me thinking about tying off. I'm not sure on your setup, but I don't have a rigid vang. I've run the topping lift back to the cockpit, and I do loosen tension when my full main is up, but I don't think I can do that reefed -- I'm pretty sure that the reefing line will not hold the boom up (along those lines, when using full main I have to raise the sail THEN release tension on the topping lift). I was definitely trying to get better shape by bringing the clew down closer to the boom. In lighter air I'll experiment with this and see if can get things to play a little more efficiently. It feels like over all I just need to spend some more time experimenting with this use of the system in a more controlled environment.
Re: the filament car
Last season I moved the stopper for the bottom filament car (furthest from the mast). I think I may have moved it too far and was putting too much tension on that particular line. The topping lift that came with this system is actually a vinyl wrapped stainless steel cable (which attaches to the topping lift line that runs through the mast and back to the cockpit). The car pulled out of the topping lift twice on this last sailing weekend. I think that I had too much tension on it at the stopper when in heavier winds. I guess that speaks to the filament strength, although I'm definitely happy the filament didn't break and/or the car didn't break. I'm not exactly sure how it squeezed its way out, but this morning I lowered the stopper AND wrapped the car in tape in hopes so as to not have this problem again.
Doug
Oct 26, 2008
6,346
Hi Doug,
I do have a Garhauer rigid vang and it would seem to make a difference. In your case, I assume that you slack the topping lift after you raise the main. I think that if you just leave it at that position (where the topping lift is tied off) when you drop the main for reefing, the boom won't drop into the cockpit. Once you reef the main, the boom will be supported by the leech anyway and the topping lift should be slack again. I think that without a rigid vang, your procedure may be a little different but the end result should not be too different. You still want the topping lift to be slacked regardless of the tension on the leech from the main sheet and/or vang sheet.
A rigid vang would be a good addition to your boat! ;)
The topping lift line on my dutchman system, which the cars are attached to is just another double braid line with eye splices / thimbles at both ends. To be sure, I haven't even inspected anything on this system in 4+ years. When I take the main down for the winter, I just roll it all up in the main for storage.
The previous owner explained that he spent a lot of time setting the dutchman up just right and I've had no reason to argue otherwise. The only issue I had is that the topping lift line to the cockpit was way longer than it needed to be and I didn't want all that excess line in the cockpit anyway. Since it was very old looking and a bit thick, I bought some new, thinner line and shortened the length. I cleat it off at the mast now because I don't want the line in the cockpit. I go forward to the mast at the beginning and end of every sail, so there seems to be no reason to need a topping lift running back to the cockpit.
capta
Jun 4, 2009
4,990
When sails had loops, hoops, or cars in tracks to attach them to booms, the buntlines were not tied around the boom. They were tied around the bolt rope on the foot of the sail only. Those little lines are only put there to "neaten" things up; they have no practical value.
As the sails began running the bolt rope in a slotted boom, the buntlines had to go around the boom, but were not intended to be pulled tight. Again, they are there only to make the sail look neater, not as a part of the reefing process.
May 1, 2011
5,209
Pearson 37 Lusby MD
:plus:
Apr 25, 2024
694
Fuji 32 Bellingham
I can hear Poseidon laughing. I would say that, in reality, reefing is nearly never done before the wind picks up. It is either done before raising the sail or it is done about 15 minutes after you should have. I don't think I have ever reefed en route in anticipation of building winds, nor have I ever sailed with anyone who has made that decision.
That said, whenever we make the decision to reef, we comment about how we should have done so a bit earlier. But, easily 9 out of 10 times we have consider reefing and decide not to, winds don't really build to the point where reefing is useful.
As they say, hindsight is 20/20. It is easy to be in high winds and say you should have reefed earlier. But, reefing in expectation of building winds means that you will frequently sail underpowered for a while before eventually letting the reef out because winds didn't materialize. We prefer to trim to actual conditions as they are, rather than as we predict. There are obvious exceptions, such as when we know or predict a storm is coming - like we see it on the horizon. But, that is rarely the case.
For us, reefing starts to be beneficial at around 15 kts, starts to be safety issue at about 20 kts, and starts to become critical at about 25 kts or so. So, "pre-reefing" really only makes sense if we are reasonably certain that winds will build from less that 15 kts to greater than 20 kts within a few minutes.
To answer the question about procedure, I think others have addressed this. For us, when we inspect/clean/repair the sail in the spring, we remove the reefing ties. If we need to reef, we thread sail ties through the reefing grommets. That's because summer rarely brings enough wind to necessitate reefing, around here. In the fall, we put the reefing ties back in place and, in the fall/winter, we are much more likely to leave the dock/anchor reefed.
Why not just leave them in place? No good reason. In my mind, having the reefing ties flopping around creates premature wear, but I doubt this is true. It is more really just that it seems silly to have them in place all summer when they are unlikely to be used.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
buntlines
I think the correct term here is "nettles," not buntlines. I think it's important to tie them, either around the boom for a bolt rope in a boom slot type sail, or around the sail only for a loose footed main, to keep the sail from flogging itself to death. Plus, it looks better. :)
Mine have always been such that there's a loop on one side of the sail and the long part on the other, so you can just secure it quickly with an easy slip hitch.
Ward H
Nov 7, 2011
3,810
@duck21
As others have mentioned, tying the buntlines to the boom is not recommended as it is too easy to get them tight enough to rip the cringles out of the sail. On my sails, both old/soft and newer stiff, never needed the reefed cloth to be tied up. It lays against the side of the boom and doesn't luff.
As for a single line system, here is what I've done. @Hayden Watson taught me this set up.
At the tack reef point and clew reef point I installed Harken Air Blocks which are very light. I used soft shackles to attach them to rings on the other side of the cringle.
I start the reef line with a bowline at the aft end of the boom positioned so the reef line goes straight up to the block at the clew reef point and back to the end of the boom, into the boom to the mast. It exits at the mast goes up to the tack reef point, through the block and back down to a block at the base of the mast, then back to the cockpit. I installed BB sheaves in the boom ends. This ensures the least possible friction.
My procedure, when I'm ready to reef, is to let out the main sheet. I then lower the main halyard to a pre marked point on the halyard for reefing. That mark puts the tack reef point about 8-10" above the boom.
I then pull in the reef line to a pre mark on that line. The clew end of the line pulls the clew reef point down to within 8-10" of the boom AND the angle back to the boom end applies outhaul tension to the clew reef point. The reef line pulls the reef tack point down to 8-10" of the boom.
I then sheet in the main. I keep the boat sailing under the Genoa while putting in the reef.
Keeping the tack points 8-10" above the boom keeps the reef line from rubbing agains the sail which would cause friction. Using all BB blocks also helps to reduce friction so the line tension is equal enough to tack and clew to provide decent sail shape.
I know that using separate reef lines for tack and clew allows better trimming of the sail but I'm very happy with my single line system.
Edit: I can put in and shake out a reef in under a minute while never leaving the cockpit.
3,202
I never tie in the reef points along the foot of the reef. In fact, when I had my new sail made, I specifically told them not to install the reef points.
The reason for my obsession about reef points is that when I bought my C30 27 years ago, the main was 18" short on the hoist and the foot was 6" short. By looking at the sail, I could clearly see that the original reef cringles had been cut out and new ones added. It is clear that a previous owner had put in a reef and tied in the reef points. Then either the tack line broke or he forgot that the reef points were tied in, and the sail was rehoisted while still tied down. The result was that the sail shredded 18" band at the reef and needed to have that torn fabric cut out and resewn together which shortened the sail 18".
Likes: Ward H
Mar 6, 2008
1,400
Foswick, one should reef as soon as white tops and larger waves are visible nearby. This confirms that the vessel will be in higher wind soon and it is time to reef now rather than wait until you are in larger waves. A good sailor must know what the water condition is trying to tell them.
Apr 25, 2024
694
Fuji 32 Bellingham
That's a really simplistic model and does not hold true across environments (nor vessels or sailors). White capping is not a good indicator of wind speed except in fairly predictable environments where the wave period and height as well as fetch are known and consistent. Around here, we get tidal convergences that cause white capping in the complete absence of wind. True, decades of experience have allowed me to get a sense of what the wind is actually doing in the distance, but it has also taught me to wait and see what is going to stick.
Also, wind and waves don't always go together in predictable and consistent ways. In your area, it is fairly consistent. But, in many parts of the world (like my area), conditions are much more capricious. If you reef and shake out or add/remove sail every time you see a change in conditions on the horizon, you will do little else.
The advice to reef early is safe and sound, and that's what the text book says, but my point is that almost no one does this. In fact, I would say that the more experienced a person is, the less likely they are to actually follow their own advice on this. We know that we can handle it if things get a bit interesting, so are less likely to proactively reef, out of concern that conditions might stiffen.
I taught sailing for some time and would advise students to reef early because that is the safe thing to do. But, it most certainly isn't what is actually done, in practice. Not among experienced sailors. We all wait until the decision not to reef is conspicuously the wrong call. Don't believe me? Take a poll. If being honest, 9 out of 10 experienced sailors will admit to consistently waiting too long to make the decision to reef.
Ultimately, knowing whether reefing is the right call is something you only get to find out in retrospect.
jviss
Feb 5, 2004
7,090
I reef to the forecast, often before weighing anchor. I find it easier to shake out a reef than take one, and it's better to be safe than sorry. Besides, my boat sails faster with less heel.
Likes: JoeWhite
