Redirecting Hunter 49 A/C unit drain pan water (condensation) away from bilge
May 5, 2017
8
Catalina 22 Huntington Lake
My only obstacle from a completely dry bilge seems to be water condensation building up in A/C unit (3) pans and draining passively into the main bilge. This has been the set up since owning my 49 and assume that is the way the system is set up from factory. Has anyone developed a set up to hook up small drain hoses to the hole bib on each A/C pan and then run into a dedicated sump, or, perhaps a way to connect to one of the vanity drains that passively exits a thru-hull below water line? When aboard and using the A/C, within a few hours, the dry bilge starts to build up water (fresh) and it would be great to divert that drain pan water overboard directly without entering the bilge first.
Thank you for any suggestions!
Mar 20, 2011
624
Hunter 31_83-87 New Orleans
Do a search on the forum for Venturi installation. There was a post sometime back that addressed this. I installed a Venturi to move condensate overboard with discharge and fixed bilge condensate problem.
7,752
Alden 50 Sarasota, Florida
This is the simplist and best solution to eliminate condensate water. You can buy a $100+ Venturi tube marketed for this purpose or better obtain one from a water bed store or big box hardware store for less than $20 which will suck condensate out with the AC pump so there is no need for more plumbing or separate sump.
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
For what it is worth, on my 420 Passage, I put a nipple in the line and ran some extra hose to one of the spare punch outs in the sump pump that is right behind the bilge on my boat. Under 50 bucks. Just a thought. Sorry I dont have a pic.
Likes: Rick486
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Great suggestions above plus you might refer to these two threads to address your question:
