Redid my floors on a C&C 32
Mar 11, 2016
6
C&C C&C 32 Stamford, CT
I use high grade marine plywood and then stained the different shades on it. After doing some sample coating I noticed that the light, thin stripes blend in when coated with polyurethane so I actually taped them off and used spray paint to highlight them. After the staining and light highlighted stripes were done I used two part epoxy from home depot, mixed and poured a thick coat on the wood. Let it dry for 24 hours, sanded with 220 and then used marine poly with UV protection to top it off. I did 3 coats of that. Then I let it dry for a week before installing. Pictures coming soon.
