I am frugal.. ok maybe cheap.. kinda..
The sheaves on my traveler are brittle now because of UV attack.. I started poking around and found that the end fittings and car would end up being $700-$800.. not a good option.. I was quoted $12 each ! for the pulleys.. amazing for a little plastic wheel ! so with 6 of 'em to change, I went on hunt and found a suitable wheel at Annapolis Performance Sailing for $4.. $24 instead of $72 instead of $700+.. I have to bore the wheel center but that really is not a problem. Keeper pin was relatively easdy to drill out .. I replaced it with a stainless screw that I was able to use as a rivet, like the original pin. I was surprised to find the lower bushing welded to the slider plate.. but other than that, no surprises.. Will post more as the job progresses.
