Rebuilding 1984 H37C
Jul 28, 2013
56
Hunter 34 Lake Norman
I am trying find out where I might get a starboard aft cleat or drawings for one. This looks to have been machined from a block of Aluminum and had a tab welded onto it to attach it to the toe rail.
May 31, 2007
773
Hunter 37 cutter Blind River
My 81 doesn't have a cleat attached to the toe rail. I suspect it is a PO upgrade, unless Hunter changed this by 84. Post a photo please, and someone will for sure chime in.
5,802
Almost certainly an upgrade. Friend's 1984 did not have cleats on the toerail, just on the coaming. I have seen toerail cleats amidships for spring line use but never at the stern. Not to say it wasn't an option. The '84 had lots of options like clutches with lines led back and a furling staysail. Does your boat have those?
Phil Herring
Alien
Mar 25, 1997
4,923
- - Bainbridge Island
I'm not aware of any OEM cleats that were attached to the toe rail, although data from the 80's is sketchy. I vote for PO upgrade.
May 24, 2004
7,174
CC 30 South Florida
Don't know of any OEM cleats attached to the rail, are there any other cleats at the stern? Like Ed indicates those are usually attached amidships for spring lines. I guess you are free to design your own, some can be found in the Chandleries.
That is usually referred to as a chock. All the H37C models have them. I don't know where they were made originally. Crest Aluminum can supply the toe rail but they don't seem to list the the chocks. Perhaps a metal shop that welds and works with aluminum could help? Or a boat salvage yard?
Nov 22, 2008
22
84 Hunter 37c bradenton
I have seen these chocks in the boat store at Catalina Yachts (no affiliation) in Largo Florida. The number is 727-544-6681 ask for Lisa Casey. Their inventory consist of over run items so you will want to send her a photo.
