Rebedding Deck things
524
Catalina C-30 Mattituck, NY
Hi all - I've been rebedding all the deck hardware on my older Catalina 30 and wanted to seek advice on various techniques everyone here uses. I have been using Butyl tape for some stuff. Basically looking at rigging hardware, teak handrails, ports, handrails - really everything bolted down....its one of those ongoing projects. Thanks - Rob
jimq26
Jun 5, 2004
860
Just for the heck of it - look in archives.
If you simply type - rebedding - into the archives on this site you will find tons of information to answer your questions. Many people seem to not be aware of this great feature.
Rick A
Slow process
With each piece of hardware I take off, I check for rot, and if necesary clean it out and repair it. It there is a core involved, I re-drill the holes to a larger size and refill them with epoxy. Once cured, I drill the hole out to the actual size needed and reinstall the hardware or the upgraded hardware. This seals the hole to prevent rot problems in the future. If I am moving something, I follow the same process.
G
gene
Rick is Rite
epoxy all thru deck fittings/bolts etc. then rebed. I used 4200
Dennis Thomas
Counter sink
Rick A has the ultimate solution of drilling out an oversized hole and filling it with epoxy. This prevents any possibility of moisture entering the core and causing rot. Many new boats are built using this technique. This was not true in the past and is still not used on all new boats. Other than that I would suggest a simple counter sink bit for your drill. Before you put the stuff back, first drill out a conical depression at each hole using the special counter sink bit. Then fill the hole with your choice of seal. The space provided by the counter sink acts as a kind of “O” ring that will help seal the hole in your boat. S/V Anodyne
Joe
Jun 1, 2004
8,311
rebed with polysulfide
such as 3M 101. This subject was discussed at length just a few days ago.
Dec 2, 1999
15,184
Nothing wrong with butyl either.
There is nothing wrong with butyl tape. If you are looking for a caulking/sealant 101 or Life Caulk are excellent options. Be sure that you do NOT tighten down the hardware until the caulking has cured for about 24 hrs. This allows the caulking to form a gasket and will not squirt out when the final seating of the hardware occurs.
