- Dec 30, 2009
- 680
Hey all, I have a ? about tranducers, my hull is made of solid hand layed fiberglass, reinforced by glassed wood stringers, approx 1-1/4" thick. Will a thru hull transducer work here? Red
You didn't mention if your transucer was a true thru hull or one that was mounted inside the hull?Hey all, I have a ? about tranducers, my hull is made of solid hand layed fiberglass, reinforced by glassed wood stringers, approx 1-1/4" thick. Will a thru hull transducer work here? Red
The advantage that I find with the fish finders is that they allow you to see the contour and slope of the bottom. If I hve 8 feet under the stern I usually have about 8 feet under the bow. BUT not always I ran hard aground in the Wye River with 7 feet showing on my sounder at the stern. It wouldn't have helped if the transducer had been hanging from my anchor roller The bottom is just plain lumpy in places in that river.I'm more interested in knowing how deep it is ahead of the boat than under it. I wonder if it could be mounted to angle ahead.
