Re: thru hull transducers
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
Hey all, I have a ? about tranducers, my hull is made of solid hand layed fiberglass, reinforced by glassed wood stringers, approx 1-1/4" thick. Will a thru hull transducer work here? Red
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
If it shoots 100' in the water, it will shoot through 1 1/4" of fiberglass.
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
Try it before you glue it in - put it in a ziplock bag of water and try it in various spots to see where your best signal is.
Dec 30, 2009
680
I have heard it will not shoot thru certain hull compositions...
Hunter 25_73-83 NORTH POINT MARINA/WINTHROP HA IL
through hull installation
You didn't mention if your transucer was a true thru hull or one that was mounted inside the hull?
Ross
Jun 15, 2004
14,693
Ultrasonic transmission is best through a single medium. When ever anything is added you lose some quality. If you have a foam cored hull you won't get through the several sound barriers. If you have a solid glass hull you will get along fine.
I often wonder if the transducer is mounted on the hull and is not perpendicular to the bottom does it sense the bottom off at angle from the boat?. If you shined a flash light slightly off to one side of where you were walking you wouldn't see the path but you might see the wall of the cliff face up or the edge of the narrow ledge you are walking.
Gary_H
Nov 5, 2007
469
Cal 2-25 Carolina Beach NC
I'm more interested in knowing how deep it is ahead of the boat than under it. I wonder if it could be mounted to angle ahead.
Dec 30, 2009
680
Ross just answered my ?, my hull is solid hand layed glass, I have not bought a new one as I wanted to be fairly sure it would shoot thru my hull composition. As far as aiming it forward, I think they reccomend up in front of or even wf the keel, its sonar that shoots a specific cone shape and has different accuracy levels, I think depending on the angle. They have different angle models so you shoot straight down...Red
Ross
Jun 15, 2004
14,693
The advantage that I find with the fish finders is that they allow you to see the contour and slope of the bottom. If I hve 8 feet under the stern I usually have about 8 feet under the bow. BUT not always I ran hard aground in the Wye River with 7 feet showing on my sounder at the stern. It wouldn't have helped if the transducer had been hanging from my anchor roller The bottom is just plain lumpy in places in that river.
