Raymarine ST4000+ Auto Pilot clutch pop out
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
On my older version, there are 6 or so “wheels” inside that support the ring and allow it to move pretty easily. I don’t know if they changed that in later models.
As on mine, which as an Autohelm unit. Those wheels, "bogies," as I refer to them, are mounted on cast plastic bosses. These can break off. I "upgraded" my pilot by drilling them and inserting small, metric, flat-head screws with locking nuts. The flat heads were outside, and the plastic countersunk for them.
Growl
Oct 11, 2020
109
Hunter 28 2 Alamitos Bay Marina
I could actually adjust the tension knob now that I had it off the wheel. I guess rinse out with soapy water and mount to wheel?
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
I repaired mine because the clutch would not disengage and would make a chattering noise.
The the tiny roll pin in the lever handle sheared off they are hard to find I found them at Granger and Napa it's a 1/8"
roll pin
I have yet to actually use the autopilot to stay a course but, if you get near (the flux Compass or whatever they call it) with your cell phone it can take you go way off course! on my other boat I actually would steer my b with the magnetic field from my cell phone just by holding it near the control unit
Likes: jviss
jviss
Feb 5, 2004
7,089
Yes, I had to be careful about putting my Fujinon binocs with compass near the control head. Or steel scuba tank in the cockpit locker. :(
Growl
Oct 11, 2020
109
Thanks for your help Greg and everyone.
I’ll put it all back together and see if it works tomorrow and let you all know!
Likes: Tally Ho
Growl. It is difficult to give directions when i feel like walking through a mine field. Or suggestion of surgery with the doctor blind folded.
Only skimpiest amount of dry lube to the places indicated. Like waving the drop near the unit but not touching it. Follow the red letter caution. No lube on the drive belt.
The image of breaks in the drive wheel. These caused the drive wheel to slip snd jump. They showed up as chatter and this caused the clutch to pop. Be sure you have all the ball bear in place. Each one fills one of the spots on the drive wheel.
Take care in tightening the screws. You want the snug but not over tightened.
I was the investigative type, so I did take mine apart.
That is how I cleaned out the small amount of accumulated dirt/dust/sea salt beneath the metal plate. It is also how I got to the "eccentrics" to add the "TINY" (not more than a smear using my little finger) of dry lube to the INSIDE of the clutch rollers. This allowed me to more easily adjust the clutch tension after I reassembled the wheel. The clutch rollers apply the pressure to the belt. The Eccentrics rotate inside the clutch roller and provide the adjustable force against the clutch roller. The TINY (just a hint) amount of lube inside the clutch roller allows the roller to rotate over the outer side of the eccentric. The roller rotates against the belt and no lube should be between the belt and the clutch roller or on the belt.
This feels like a sitcom or one of those movie series on a Saturday known as Cliff Hangers.
Growl
Oct 11, 2020
109
LOL, this might be an all day event I still have to find the dry lube at the hardware.
My Candy store of choice.
I am required to leave my wallet at home.
They teach the store staff how to do a walletectomy on all visitors.
Good image of wheel.
I did not see any cracks in the plastic wheel. You have come corrosion going on with a few of the metal inserts designed by AutoHelm to receive screws from Helm Wheels with differing spoke patterns.
I would treat all of those with a product called Corrosion Block. It can be found at West Marine or many other places. I prefer the no pressure spray container (I purchased mine from the manufacturer Lear Chemical -https://www.learchem.com/products/corrosion-block.html). A small squirt on a Q-Tip, then rubbed on the metal insert will clean the corrosion and provide a layer of protection.
I found this stuff to be exceptional I sprayed a little on a cheap master lock and left it out in the marine environment 24/7. 18 months later fully functional and just starting to show a touch of corrosion. Time for another application.
