Ray marine Smart pilot st6002 error message question?
Jan 24, 2017
670
Hunter 34 Toms River Nj
I have had this ray marine smart pilot st6002 for the past five or six years now and has worked perfectly up untill this past season. The controller is giving a error message!!
"Mot pow swapped"
Owner Manuel alarm message idecates possible cause and solution is
Motor cables are connected to power terminals and power cables are connected to motor terminals at the computer.
Solution is turn off power and swap over the connections.
Note these cables are connected correctly and have been for the past five or six years.
Nothing has changed.
Things that I have done so far as per manual.
1 swapped cables as listed above, not resolve so moved them back to original locations.
2 cleaned all wires and reconnected.
3 checked all fuses.
4 checked all wires for breaks or damage.
Everything appears good. However the error message is still displaying.
Called ray marine tech support they needed more info off the unit which I will get them later in the week, however they don' t appear to have a clue what is wrong.
The strange thing is that the unit worked fine for years and now out of the blue this error message appeared. Nothing has changed.
Also note that this unit is not inter grated with any other electronics. And I don't use this very much at all, maybe once or twice a year.
Anyone here ever had this problem?
Apr 26, 2020
41
Catalina 310 WPB
"Mot pow swapped"
Just ran into the same issue yesterday, did you find the solution? Much appreciated!
Mar 6, 2008
1,298
I would clean the motor contacts with 400 grit sand paper lightly. The female jacks, roll the sand paper and insert in the opening. Apply lanoline on male and female plugs. Check all the screw blocks providing power, clean as above. It may be due to corrosion.
Mar 17, 2024
2
Morgan 33 St. Augustine
Hello Captain Rob,
I have the exact same error message coming from my S2 Raymarine auto pilot.
Mot Pow Swapped. It appeared under the same conditions.
Worked fine, boat sat up for a couple of months now this message when I came off the hard.
Did you find the fix?
Thanks,
Atlanticbrew
St. Aug. Fl.
Mar 17, 2024
2
It's possible. I called a Raymarine representative and they recomended Seawire Marine Electronics in Miami.
I googled reviews and they had a good rep. so I mailed them course computer.
Hopefully it's not fried or I'll go start cleaning connections.
Thanks,
Atlanticbrew
Oct 13, 2024
1
One Off Endurance 35 Amsterdam
Hello Atlanticbrew,
I was just wondering if and how you solved this problem.
I am getting the same error message intermittently on my boat too.
The most confusing part is that it is intermittent... One day it's here, the next day not.
Would be very grateful to know what the diagnosis was!
Best regards and fair winds!
kbcole
Dec 28, 2024
1
Taswell 43 Greenville, SC
Greetings, my system is now giving this exact same error after working fine for years. All contacts have been cleaned to ensure good connections. What cause has anyone found to get a Mod Pow Swapped error, and what were the solutions to fix?? Many thanks
