Raw water pump
3
catalina c30 Victoria
I have a 1987 C30, power plant is M25 xp. My raw water pump is leaking from pressure releif hole, 1st Q. replace pump or rebuild ( seals etc. ) 2nd Q. Can I replace Sherwood pump with Oberdorfer ( good or idea ? ).
Rob
M25 series raw water pump
Rob,
Check out our Critical Upgrades topic on our C34 Message Board, reply #11: http://c34.org/bbs/index.php/topic,5078.0.html
There are lotsa links on that topic about other things, too, also to our C34 Tech wiki with lots of info on your engine:
http://www.c34.org/wiki/index.php?title=Diesel_Engine
You can get an Oberdorfer. Ours is just great compared to the Sherwood. Much easier access to the faceplate to change the impeller. You can't get discount prices on a Sherwood. DEPCO does Oberdorfers, try a search on our MB on that word, lots of reading.
Either redo the seals, the pump usually is just fine, or swap the pump.
Oct 6, 2009
129
Newport Newport 28 MKII Jacksonville, FL
just went thru this, Depco was far more competitive on the impeller, seals and pump than several other well-known suppliers for Universal parts.
