Jack Walsh
Catalina newbie here. I just purchased an '84 C30 Tall Rig that's powered by a Universal M-25. Though I've sailed for years, I have almost zero experience with the M-25 or any marine diesel engines for that matter.Can anyone here tell me where the valve for the raw water intake is located? Is it on the port side under the galley? I know this engine is fresh water/coolant cooled. I believe this valve should be closed shortly after turning off the engine? So you must have to open it prior to starting the engine. I know the raw water intake is used as a heat exchanger for the fresh water cooling system.If anyone has a pic (or a link) they could put up, it would be greatly appreciated.-Jack
