Okay, so as not to completely hijack Rodd's thread re: drilling/opening clogged external strainers, let me post this thread and ask a few questions.
See my attached schematic below, as a first idea about how to do a better replacement raw water system for My C27 with Atomic 4. Per recommendations yesterday I want to go with at least a 1" thru-hull, and I want to go with a flanged seacock. I prefer the Forespar stuff, so it will need to be 1.5" for the mushroom fitting and seacock. I might as well go 1.5" plumbing up to the strainer, since the Forespar strainer is 1.5" inlet and outlet, (and I think I have one from a parts boat!). Coming out of the strainer, I can reduce to 1" or 3/4" depending on what the motor wants, and go past a y-valve to make life easier for flushing and winterizing maybe.
As I type this I realize what I drew is not going to be convenient for winterizing the actual plumbing, only the motor... So, based on trying to design a proper system that is easy to clear AND winterize, what recommendations would you make to ammend the drawing? Also, how high can or should the strainer be, and if well above waterline, is there a need for a check valve in the plumbing?
If I am going to spend the money, I want to do it once, and right!
