A
Anthony Bavuso
Peggy,What do you think of the Raritan TWK (Toilet Water Kit). It's about $50 so it's not a trivial addition. I have a Raritan PHII manual head and I am going through the steps the remove the odder. I have been reading your library, you have a lot of great tips and info, thanks!Would you recommend that I install the TWK as part of my attacking the head odor problem campaign or would you recommend me going through the other steps you recommend first and then if I still have an odor problem getting the TWK?Also another question regarding the inlet water smell. You recommended in one of your library articles installing a common automobile type radiator flush valve to use to put fresh water into the intake hose and toilet. I am a little concerned about installing an automobile part into the salt water system. It would seem to me that the salt water would make short work of the radiator flush valve in no time. Can you allay my fears? Do you know of someone who has installed the automobile type value for a salt water boat? How long did it last? Thanks again for all your help.
