So I installed a solar panel running it through an MPPT type controller. The controller is mounted above the companion way steps, so about 6 feet from the fixed mount VHF down below and the same distance from the hand held in the cockpit and I am getting a bunch of backgroud static. If I take the hand held and go forward on the boat, problem solved, so I know (think) it is the controller. If I cover the panel with a blanket, no change.
Anyone had this problem and can offer a solution?
I am also going to put this question to the maker of the controller soon as I get back to the boat and get a name off the controller.
