"MaxProp" info - paging Nico Walsh! :)
Sep 30, 2013
3,713
Hi Nico, are you out there?? I was wondering if by chance you know the specs/model/whatever of that beautiful masterpiece prop you had on Journeyman. I'm on the fence as to whether to go that route or just get an "infallible" three-blade 12x9RH like most folks go with.Thanks in advance for your knowledge!- Gene Neill
Sep 13, 2002
203
FYI, I'm just about to install a replacement 13x10 for my MkI Vega with Yanmar 1GM10. The previous 13x10 three blade succumbed to decinfication after 20 years.Alisdair
Oct 30, 2019
1,459
I really don’t know the prop specs, except that it is a Maxprop 3 blade. The prior owner installed it. It was a very reliable, robust installation, trouble free. I was careful about zincs and annual lubrication. We put one on our new boat. I would think a good prop shop could fit one to a Vega. The prop is adjustable, so if pitch is a bit off that should be fixable.
Nico WalshNicholas H. Walsh P.A.Admiralty and Maritime Law; Probate Litigation; Commercial LawPhone: (207) 772-2191Fax:     (207 774-3940P.O. Box 7206120 Exchange St.Portland ME 04112This message is from a law firm, and may contain information that is privileged and confidential. If you suspect you are not the intended recipient, please delete the email and call us.
Dec 14, 2013
50
Albin Marin Vega 27 Venice
Hi Gene,I am repowering my series III Vega with a Beta 14 (10 KW power) with transmission Technodrive TMP 40P (reduction 2:1).I visited recently the Max-Prop factory in Milano as I live 2 hours drive from there. For the my Vega and based on the engine and transmission, they recommend the 13 inches prop (33 cm). The pitch is adjustable and they suggested 20°.I want to keep the ability to replace the Max-Prop with a 12x9 fixed blades myself in case the Max-Prop gets damaged. For this reason they suggested me the "easy" model that can accept a longer threaded end of the shaft (for a standard nut, required for the standard prop).This prop is heavier than the standard ones so my mechanic has suggested to keep the shaft length between the rear bearing and the prop hub as short as possible. This means mounting a zync on the prop nut and not a ring version on the shaft.MaxProp - automatic feathering propellers worldwide production leader MaxProp - automatic feathering propellers worldwide production leader Fair winds,marcoAlbin Vega 3339 Spray From: "gene_neill@... [AlbinVega]" <AlbinVega@yahoogroups.com> To: AlbinVega@yahoogroups.com Sent: Sunday, 18 December 2016, 1:10 Subject: [AlbinVega] "MaxProp" info - paging Nico Walsh! :)
Hi Nico, are you out there?? I was wondering if by chance you know the specs/model/whatever of that beautiful masterpiece prop you had on Journeyman. I\'m on the fence as to whether to go that route or just get an "infallible" three-blade 12x9RH like most folks go with.Thanks in advance for your knowledge!- Gene Neill
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494 --
#ygrps-yiv-1697442853yiv9219960494ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mkp #ygrps-yiv-1697442853yiv9219960494hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mkp #ygrps-yiv-1697442853yiv9219960494ads {
margin-bottom:10px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mkp .ygrps-yiv-1697442853yiv9219960494ad {
padding:0 0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mkp .ygrps-yiv-1697442853yiv9219960494ad p {
margin:0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mkp .ygrps-yiv-1697442853yiv9219960494ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-sponsor #ygrps-yiv-1697442853yiv9219960494ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-sponsor #ygrps-yiv-1697442853yiv9219960494ygrp-lc #ygrps-yiv-1697442853yiv9219960494hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-sponsor #ygrps-yiv-1697442853yiv9219960494ygrp-lc .ygrps-yiv-1697442853yiv9219960494ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494activity span {
font-weight:700;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494activity span span {
color:#ff7900;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494activity span .ygrps-yiv-1697442853yiv9219960494underline {
text-decoration:underline;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494attach div a {
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494attach label a {
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494bold a {
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 dd.ygrps-yiv-1697442853yiv9219960494last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 dd.ygrps-yiv-1697442853yiv9219960494last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 dd.ygrps-yiv-1697442853yiv9219960494last p span.ygrps-yiv-1697442853yiv9219960494yshortcuts {
margin-right:0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494attach-table div div a {
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494attach-table {
width:400px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494file-title a, #ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494file-title a:active, #ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494file-title a:hover, #ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494file-title a:visited {
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494photo-title a, #ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494photo-title a:active, #ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494photo-title a:hover, #ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div.ygrps-yiv-1697442853yiv9219960494photo-title a:visited {
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 div#ygrps-yiv-1697442853yiv9219960494ygrp-mlmsg #ygrps-yiv-1697442853yiv9219960494ygrp-msg p a span.ygrps-yiv-1697442853yiv9219960494yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494green {
color:#628c2a;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 o {
font-size:0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494photos div {
float:left;width:72px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494reco-category {
font-size:77%;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494reco-desc {
font-size:77%;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 .ygrps-yiv-1697442853yiv9219960494replbq {
margin:4px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mlmsg select, #ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 input, #ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mlmsg pre, #ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 code {
font:115% monospace;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-mlmsg #ygrps-yiv-1697442853yiv9219960494logo {
padding-bottom:10px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-msg p#ygrps-yiv-1697442853yiv9219960494attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-reco #ygrps-yiv-1697442853yiv9219960494reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-sponsor #ygrps-yiv-1697442853yiv9219960494ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-sponsor #ygrps-yiv-1697442853yiv9219960494ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-sponsor #ygrps-yiv-1697442853yiv9219960494ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1697442853 #ygrps-yiv-1697442853yiv9219960494 #ygrps-yiv-1697442853yiv9219960494ygrp-vital ul li:last-child {
border-right:none !important;}
Apr 12, 2016
102
That's very exciting, Marco! I wish I lived in Italy, so I could come see your Vega! She certainly bears a grand name. :)I too am repowering a Series III Vega (#3360) with the exact same engine and transmission that you are using. Are you doing the work yourself, or are you having it done by a professional? I'm getting ready to start removing the old MD7a, although I have absolutely no idea what I'm doing. LOL
May 30, 2006
1,075
13x10?thats what previous owner had run on my md6a. was its eventual cause of death. was way over proppedSent from my iPhone
Sep 13, 2002
203
 I ran it past the new prop maker and that’s what was recommended .. maybe it’s down to gearbox ratios.The previous prop ran out of zinc, but the engine’s still running sweetly (well, as sweetly as a twenty year old single cylinder marine diesel can)        From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] Sent: 19 December 2016 22:30To: AlbinVega@yahoogroups.comSubject: Re: [AlbinVega] Re: "MaxProp" info - paging Nico Walsh! :)  13x10?thats what previous owner had run on my md6a. was its eventual cause of death. was way over proppedSent from my iPhoneOn Dec 17, 2016, at 7:42 PM, yahoo@... [AlbinVega] <AlbinVega@yahoogroups.com> wrote:
Apr 12, 2016
102
Side note: MaxProp claims their props will increase forward speed by FIFTEEN PERCENT, can this possibly be true?
May 30, 2006
1,075
i also have the max prop and their recomendation was correct. if your prop is correct, iirc, you hit max throttle-max rpm and no more? something like that.when i first bought my vega, i could only get like 1500 rpm with black smoke. 3-4 knots in flat water.Sent from my iPhone
