Sure John, I see what you mean...
just about ANYTHING would be better than the wiring that came from the factory, but I figured as long as I was going to all the trouble and expense of fully re-wiring my 26D, I might as well follow the code and use marine grade everything. Having been an electrician for over 20 years and being a licensed electrical contractor/engineer, I've grown quite accustomed to following the NEC (National Electrical Code), so it was easy for me to get into the ABYC (American Boat and Yacht Council) wiring requirements, which state that solder shall not be used as a sole means of connection. Soldering is also illegal under the NEC. Sooo...you could first crimp and then solder, but it seems to me that a coating of anti-corrosion gel, a secure crimp and a bit of adhesive lined heat shrink is the preferred method, and fully compliant with both ABYC and NEC requirements. Yes, I understand what you mean about the lack of vibration on a sailboat, (if there was a vibration on my boat harsh enough to disturb the wiring, wiring would be the least of my worries!) but what about connections to an inboard motor? As far as the cost of the tools to do a proper crimp, you are quite right that they are expensive. The crimp tool I have for sizes #8-#2 costs about $400 new (got mine on E-bay for 85 bucks), but a controlled cycle tool for sizes #16-#10 can be had for under $100 new.Plain copper wire (stranded, of course) will indeed function in a marine environment, but why try to save a few bucks when approved marine grade wire is so easily available? Marine grade wire is designed specifically for the job, in that it is of fine strand (type 3) construction, tin plated, insulated with a compound that is resistant to oil, gas, fungus, water, etc. and carries the appropriate approvals from the C.G., U.L., etc. For all the trouble I went through routing, tying and terminating the stuff, there was no way I was going to save a few bucks using inferior materials. (BTW, not all marine grade wire is created equal, the 'Pacer Marine' wire carried by bestboatwire is, IMHO, of higher quality and easier to work with than the 'Ancor' brand carried by W.M. There is also a huge difference in price, with the 'Pacer' being about 1/3 the cost of the Ancor)Anyhow, as you said, the final decision is up to the owner, but I still think it's worth the time and money to do a first rate job, knowing that the wiring on my boat is, as we say in the trade, a 'hundred year job', meaning that the work is of such quality that it will never need replacement in my lifetime. I also feel that a fully compliant wiring job adds value to the boat when it comes time to sell, but that is another matter entirely. Feel free to do whatever you want, but I'm sticking to the code! Jeff
