Jack Walsh
Hi All,I own an '84 C30 TRBS w/ fresh water foot pump in the galley and a hand pump faucet in the head. When we are heeled over on a starboard tack the faucet in the head starts to leak fresh water. Has anyone else experienced this problem? If so, did you find a solution?To top it off, even though the sink drain hose valve is open, the sink does not drain while heeled, only when we are resonably upright.Also, do other C30's head sink drain hose connect to the raw water intake hose for the head ( a tee connection into a through hull)?Thanks in advance,Jack
