Going to do the same on my 222,,.
Hi Kevin,I'm hopping to do exactly the same at haul-out. Glad to read how easy it was for you. My centerboard has a chunk, I call it a bite out of the back upper quarter. Purchased my 222 in late spring so when I went to launch off the trailer the water at the ramp was to shallow. Then I went to extend the tongue on the trailer only to find that previous owner hadn't used the sliding mechanism.. For wanting to get the boat in the water I hired the marina's travel lift. While suspended in the slings and dropping down the centerboard and discovered the bite. Rather than getting excited about the problem I launched anyway and will deal with it this winter.Don't know, but I think they are plywood cored. ?? Mine didn't seem heavy when I manually lifted it and made sure it could move freely. Of course it maybe heavy now with the core being soaked. Plan to keep it near my furnace for two or three months. Also I read there is a ss cable connected to the pendent and the pendent has the rope that feeds up to the cockpit. The new replacement does not use the ss cable,,, Hummmm I would think the cable would create less drag while centerboard is in the lowered position. What is you plan for this situation.??
