PSS DRIPLESS question
Apr 29, 2012
67
Catalina 30 TRBS Lake City Marina
Looking to replace pss dripless on my 1987 catalina 30 tr, need to know stern shaft log dia. I tried to measure it and it looks to be1 3/4" or a bit less, possibly 1 5/8", anybody know for sure? Thank you
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Wonder if PSS has a record of your shaft seal? If not, this thread describes one boater's method to measure the stern tube diameter.
Jun 2, 2014
606
Catalina 30 mkII - 1987 Alamitos Bay Marina, LB, CA
I know this is late, but for reference, I have the same year 87 mkII boat and I measured the outside diameter of my stern tube to be 1.6"
PYI (PSS) told me to order:
Part number for standard speed seal for a 1" shaft and 1 1/2" stern tube is 01-100-112. The bellow will stretch up to an 1/8" so you will be good to go there. List price is $310.
Also for reference, the "standard speed seal" does NOT have the vent hose attachment on it. I didn't have one, and they say you don't need it on a sail boat. So, if you don't already have the plumbing for it, you don't need to order the one with the vent hose. They just suggest to "burp" it after a haul out and once in a while when you inspect it.
leo310
Dec 15, 2006
651
Catalina 310 44 Campbell River BC
I would recommend that you get the PSS with vent and hook it to the output of your raw water pump. The reason for this is I replaced one last year and it failed and PSS rep stated that a person should only install a vented type. The unit was replaced and upgraded at no cost.
JamesG161
Feb 14, 2014
8,032
Hunter 430 Waveland, MS
:plus::plus:
But before the high point vent of the raw water loop. My vent is "Pressure to Close", thus when no more water pressure, the Vent opens to break a siphon.
Jim...
RoyS
Jun 3, 2012
1,742
Have used the unvented one for decades. Burp it once when I launch in the Spring. I also had the 1-5/8" stern tube and stretched the 1-1/2" bellows.
Jul 7, 2004
8,536
Hunter 30T Cheney, KS
My LasDrop instructions said sailboats only need to vent the seal. Only higher speed stinkpots need positive flow.
JamesG161
Feb 14, 2014
8,032
I posted the part number of the non-vented one. I just ordered and received it last week.
Special order, not on their web site.
But good info....
Jim...
Apr 29, 2012
67
Thank you for all of the replies. I contacted catalina yachts and the engineer said that back then the shaft log was hand made so there was a lot of variation in the thickness. I have since checked the thickness with a caliper and got 1.706" so I went with a 1 3/4" bellows.
