I do know today's lubricants are significantly better than they were "back in the day". My 50's era outboard motors were designed to be mixed 24:1 with 30WT automotive oil. Today we use TCW3 as a better lower-carbon-fouling substitute, (still 24:1, I don't like rebuilding power heads and oils is relatively cheap). Many LU lubes are now synthetic, and are certainly multi-season. I would suspect that a 2008 Honda probably has synthetic in it. just a hunch, I have not searched it yet.
I have to consider your comment in context. Your example points to a season of heavy use. My little vintage runabout's '57 Johnson got drained and refilled every year, because I used it a lot. I mean like every weekend for several years until I finally put it in the shop and covered it up. On that point, you and I are on the totally same page.
For context, I am 30, so this was 15-20 years ago. Not so long ago that the oils have changed too much. I do remember about the time when TCW3 hit the market, My Dad saw a significant reduction in burned pistons in engines!
I don't disagree with you, but that is for a truly light duty use. Many people think they are light duty because the boat isn't moving fast, but they really are not. If you often run the engine for more than an hour at a time, or at 50% or more throttle, that isn't light duty.Considering the light duty asked of an outboard sailboat auxiliary though, I have no problem at all recommending that LU lube can go two or more seasons, assuming the motor has not been punished, there is no excess of wear metal, and the lube is dry and the same color as when it was first put in. If it has browned or darkened appreciably, as that is a visual clue that there is a need to change it.
Many lake sailors probably are actually light duty, but anyone on a river or bigger water probably does not fit that definition. So in the interest of being safe, and not having anyone mis-understand what light duty is, I'm going to stick to my reccomendation that people change their oil annually, unless you know and understand what is going on, to get away with changing it less often.
This is what I use. I'm sure other products work well, but this has worked well for my Dad, myself, and also another guy I know who does entine repair for a living, and have never seen a reason to look for something else.caguy said:Do you have a brand of oil you recommend?
Quicksilver High Performance Gear Lube
Full disclosure, I do sometimes skip changing it for the same exact reason you do, but that's because I know when the oil is still close enough to new to get away with it without any risk to the engine.
