Wow!  Thanks, for dragging me down this rabbit hole...
I had a brief exchange with Peggy, earlier this year about a spreadsheet that I had found and hoped to use to calculate how much bleach to use;
Smelly “fresh” water
WRT the original question, here; "...what causes the difference..." in the recommended 'amounts'?  I think it comes down to recommended concentrations for different methods used to treat specific components of a water system.  In looking at the spreadsheet that I have (purpose; to calculate the amount of bleach to use in a specific volume storage tank);
- A concentration of 200 mg/L is referred to as "Spraying or brushing on..." (to a surface?), and not included in the spreadsheet.  In the document that @RitSim linked, there are photos of storage tanks whose capacities are obviously greater than the 550 or 850 gallons of solution which are the subject of the sample calculations, likely to be surfaces to be sprayed or brushed with 200 mg/L solutions.
- A concentration of 10 mg/L is used to fill a "tank or reservoir", and allowed to stand for 6 or 24 hours.
- A concentration of 50 mg/L is used to fill a "reservoir", and allowed to stand for 6 hours.
Variations are referenced (in the spreadsheet that I have) for both 10 and 50 mg/L concentrations when used for "pipes" or "wells", and allowed to remain for 24 hours in each case.
Obviously, we don't want to consume such high concentrations, so we flush the tanks after the appropriate treatment period.
My question, what is the best method for treating our small water systems, and what is the best method for flushing residual chlorine?  My thoughts are that, once the initial treatment solution has been drained from the domestic water tanks, that I probably don't need to completely refill them to remove the remaining high levels of chlorine.  I could probably get most of that out with a quarter of a tank or so of additional flushing.  I also decided that I could use some of that flushing water to run through my holding tank this past spring.
I'll be watching.  Hope to learn something from this one!
