Propeller sizing
12
2 34 us virgin islands
Any recommendations out there for propeller type/size for yanmar 3 gmd 30 on a hunter 34 1986
Dec 2, 1999
15,184
What's your problem?
Got a prop? Need a prop?
I suggest that you find a prop shop to get you a proper blade for your boat.
Do you have a budget? $500, $1000, $2000 $2500?
Michigan Sailor, Campbell Sailor, Kiwi, .........
Ross
Jun 15, 2004
14,693
Reduction gear ratio? It all matters. Restrictions on diameters because of clearances?
Sep 21, 2009
385
Hunter 34 Comox
HI, here are 2 recommendations for a prop for your boat from Norm at West by North, I went with the Campbell, thinking that I would mostly be cruising. It works great, the 2 blade vibration is gone. I can't quite hit 3300rpm but never cruise at that anyway. I left the price in so you can get an idea of what you might spend. I bought 2 years ago. Hope this helps
"Based on the information that you have provided, we would recommend a CS3RH14x9x1 for your installation. This is a Campbell Sailer, three blade, Right Hand rotation, 14" diameter, 9" pitch for a 1" shaft. This size is recommended to give you a good cruising rpm and still have reserve for head wind and seas.
This propeller would cost you $565.00 plus taxes.
The Kiwi Feather Propeller size recommendation is for a 16" diameter x 21 degree pitch and the cost is $1395.00."
Nov 6, 2006
10,253
Original factory prop on my boat was a Michigan Wheel "Sailor",two blade, 15" pitch by 15" diameter by 1" shaft with standard taper. My transmission is a KM3A with a 2.63:1 ratio. Boat is an'85 model. Engine is a 3 GMF.
Jul 21, 2009
12
Thanks for your input
