Dan Geltmacher
Oh boy! Yesterday going out of the harbor I experienced a vibration going foward at about 2500 RPM. After shutting down the engine, under sail at about 3 knots,I looked into the engine compartment to see the shaft turning with the transmission in neutral. I could hear and see the shaft turning(it was vibrating as it turned).Going underwater and looking at the propeller shaft proved what I suspected. I was able to grasp the propeller and shake it from side to side and up and down. Which leads me to my question...Is this a bad cutlass bearing? Does the boat have to come out of the water to replace a bad bearing.This problem has not been noticed prior to yesterday.
