Prop shaft wear
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
My prop shaft has some scoring from the packing gland nut being too tight (I didn't do it!). I know this is not desirable, buy I am very tempted to repack it and keep my eye on it as I don't think the scoring will cause too much leakage. Opinions?
Oct 15, 2004
163
Oday 34 Wauwatosa, WI
You don't say what type of boat you have
but I encountered the same thing on our Oday 34 over this winter. I bought a new stainless steel prop shaft, for under $250, and took advantage of the occasion to replace the packing gland with a dripless system as well. To answer your question directly, my old shaft was badly worn in the packing gland area, but I was still able to adjust it to minimize the drips. My old shaft was slightly bent as well, and I needed to replace the cutless bearing, which all contributed to my decision to replace.
Ross
Jun 15, 2004
14,693
Higgs, When I rebuilt Bietzpadlin the engine
bedlogs were rotted. As a result the shaft alignment was way off, the shaft was scored and the packing nut was worn. If the scoring is very shallow with no distinct ridges you can probably get away with new packing. However if the boat lives in the water all summer and the gland leaks too much it can sink. My call is a close inspection first, if you just repack be very watchful. If you decide to change the shaft check everything as if it were a new engine installation.
RichH
Feb 14, 2005
4,773
Can be remedied .....
If the scoring is 'shallow' and there is no evidence of 'galling' (chunks of metal missing), then the shaft can be 'dressed' back to shape by a machinist ... the shaft is put into a lathe, emory cloth etc. is used to polish out the shallow grooves, etc. Why do the grooves need to be polished out? ... the engine sits on 'soft' mounts and with varying thrust conditions the shaft will move back and forth in the stuffing box ... and those grooves will both abrade any new packing and will be of 'variable geometry' versus sealing the water out as the shaft moves back and forth in the stuffing box. Surface roughness is incompatible with packing as it will continually abrade it. If you have the chance, pull the shaft and repolish the journal surfaces.
Feb 6, 1998
11,772
This can be fixed
A number of ways. More of these $$$$$ represent cost! 1) A new prop shaft and a refacing of the old coupling to the new shaft.. $$$$ 2) Dressing the shaft at a machine shop still requires removal of the shaft. $$ 3) Add a PSS Shaft Seal. You can most likely get the stainless rotor in a spot where there's no wear because the length of the PSS is slightly different than a standard stuffing box. $$$ 4) Add a flexible Drive Saver. This will move your worn shaft back about 1 inch and put the wear inside the male end of the stuffing box. $$
Feb 2, 2006
470
Hunter Legend 35 Kingston
Same problem ...
Good suggestions Main Sail ... I did all three of those things over the winter! ('87 Hunter Legend 35) The root of my problem was the motor mounts had sagged over the years. This caused regular premature wear on the cutless and the shaft at that point. The shaft also knocked and rubbed against the shaft log (due to the miss-alignment). The stuffing box (original from Hunter) was also in bad shape, and the shaft (bronze) was badly worn down around the stuffing area too. In all, the shaft had 3 spots where it was significantly worn down. Even with a new cutless, it was a loose fit. Anyway .... I shimmed up the engine mounts a little and got the engine properly centered going through the shaft log, cut the old shaft out (didn't fit past rudder), and figured that while I had everything apart, I'd put in a flex coupling and a PSS shaft seal. A point to note is that I had to cut the old shaft out because it would not slide past the rudder, but once the cutless was removed, I WAS able to just barely slide the new shaft by the rudder. Once everything was in place, I slid a new cutless over the end of the shaft and locked everything in place. It saved digging a hole for the rudder (impossible where I was), or removing the strut. With one of those cutless removal contraptions that let you remove it with the shaft in place, then I wouldn't have had to cut the old shaft out. Launch is in 2 weeks, and I'm hoping for a smooth ride and no leaks! Chris
Mar 22, 2004
733
Hunter 30 Vero Beach
I was lucky
I had the same problem over the winter, I replaced the motor mounts, the transmission, and put in a PSS dripless seal. I was lucky though, my shaft wasn't scored so it didn't need replacement. It's funny how the motor mounts going bad can cause so much damage.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
A possible inexpensive fix
If your stuffing box is mounted using a shaft log hose, you could go out and pick up a new hose and cut it slightly shorter than the original so the packing is riding on a spot on the shaft with no wear. Also you may gain a little piece of mind (for a few years anyway) not having to worry about an old hose rupturing and sinking your boat. Total cost is probably under $20 (I just changed mine and it was $11 not including hose clamps). Manny
John
Dripless packing from West Marine
Is a puddy like stuff that fills even very deep shaft scores .My shaft was ripped up real bad .The WM puddy lasted 4 years , then i changed the shaft becouse the yard bent it pulling the boat . The strap was on the shaft .My bilge has been dry for years. I had no reason to change the packing gland. John
sandra
FOR SALE/LRG SIDEKICK 3,D WADE SIDEKICK 3
STOPR OVER PHONE STORES INC NEW GSM PHONES/PDA - UNBEATABLE PRICES WE ARE CERTIFIED WHOLESALERS OF VARIOUS GSM MOBILE PHONES AT VERY AFFORDABLE PRICES ATTACH IS OUR VERY CURRENT PRICE LIST OF GSM PHONES FOR YOUR REFERENCE ALL PHONES/PDA ARE BRAND NEW SIM FREE/OPEN LINES/UNLOCK. We are mobile phones wholesalers and we do sale in pieces to enhance our sales.We deals on all brands and models of mobile phones such as Nokia,Motorola,Samsung,Sony Ericsson,Sagem, Nextel,Sidekick II,Sprint,Ipods, Laptops, Mp3 players etc at very cheap prices.Also, this is to reach our customers globally that its the season of BUY TWO GET ONE FREE. We are using this medium to reach interested buyers of mobile phones.Do kindly reply back if you are interested. THE KINDS OF MOBILE PHONES ARE LISTED BELOW: Email address...STOPOVERSTORES_INC@HOTMAIL.COM Email address...STOPOVERSTORES_INC@YAHOO.COM PRICE LIST BELOW!!!!!!!!!!!!!!!!!!!!! ========================================== SIDE KICK S ====================================== D-WADE SIDE KICK 3 FOR JUST...........$180USD SIDE KICK 1 FOR JSUT...............$100USD SIDE KICK 2 FOR JUST ..............$130USD SIDE KICK 3 FOR JUST...............$180USD LRG SIDE KICK 3 FOR JUST...........$160USD PINK COUTURE SIDKEICK 3---------$120USD MR CARTOO SIDKEICK .................£110USD ============================================ PLASTATIONS:Brand Playstation and XBox Game =========================================== Ninten do Wii-----------------------------$160 GARMIN 396-----------------------------$150 Playstation 1-----------------------------$120 Playstation 2-----------------------------$130 Playstation 3-----------------------------$180 Sony PSP Value Pack---------------------$105 XBOX GAMES: Xbox 360 Core System ------------------- $163 Xbox 360 Prenium pack ------------------$190 Xbox 360 Platinum Bundle Console ----- $155 Intec G8600 Xbox 360 9.2 TFT Screen--$85 ============================================== Noka N Series: =============================================== Nokia N95--- $250 Nokia N70--- $170 Nokia N71--- $170 Nokia N72--- $170 Nokia N73--- $170 Nokia N80--- $180 Nokia N90--- $170 Nokia N91--- $180 Nokia N92--- $200 Nokia N93--- $210 Nokia 8800 --- $200 sirocco Nokia N-Gage--- $175 Nokia N-Gage QD--- $180 cNokia 6680-----------$160 Nokia 6060-----------$240 Nokia 6111------------$200 =================================== Motorola ================================== Motorola A388C......170 USD Motorola A760.......250 USD Motorola A768.......260 USD Motorola A768i......200 USD Motorola A780.......290 USD Motorola C550.......90 USD Motorola C650.......100 USD Motorola E365.......100 USD Motorola E398.......120 USD Motorola E680.......240 USD Motorola RAZR V3....270 USD Motorola V220.......170 USD Motorola V303.......100 USD Motorola V400.......150 USD Motorola V500.......150 USD Motorola V501.......200 USD Motorola V525.......150 USD Motorola V600 (OEM) w/ Bluetooth Headset..260 USD Motorola V600 OEM...180 USD Motorola V690.....170 USD Motorola V750.....180 USD Motorola V80......200 USD Motorola V80 with Bluetooth...260 USD Motorola V872.....200 USD Motorola V878....180 USD Motorola V300....150 USD ================================= Samsung ================================ Samsung D600...260 USD Samsung D500...240 USD Samsung E600...140 USD Samsung E800...180 USD Samsung P510...120 USD Samsung SGH-D410.200 USD Samsung SGH-D500..270 USD Samsung SGH-E700..150 USD Samsung SGH-E715..170 USD Samsung SGH-P100..130 USD Samsung SGH-P400..95 USD Samsung SGH-P408..240 USD Samsung SGH-P730..150 USD Samsung SGH-S200..90 USD Samsung SGH-S300..70 USD Samsung SGH-S300M..100 USD =================================== Sony Ericsson ================================== Sony Ericsson W910--US260 Sony Ericsson W900--US250 Sony Ericsson W810i--US200 Sony Ericsson W800i--US200 Sony Ericsson P800-- US$155 Sony Ericsson P900-- US$205 Sony Ericsson P910i-- US$210 Sony Ericsson R520m-- US$100 Sony Ericsson R380 World-- US$90 Sony Ericsson R380s-- US$105 Sony Ericsson R600-- US$35 Sony Ericsson S700-- US$175 Sony Ericsson K500i-- US$180 Sony Ericsson K700i-- US$189 Sony CMD-J5-- US$30 Sony CMD-Z7-- US$35 Sony CMD-J7-- US$40 Sony CMD-J6-- US$40 Sony CMD-Z5-- US$90 Sony CMD-MZ5-- US$155 =========================================== Siemen =========================================== Siemens A35-- US$15 Siemens A40-- US$19 Siemens A50-- US$25 Siemens A52-- US$29 Siemens A55-- US$30 Siemens C45-- US$30 Siemens C55-- US$35 Siemens CL50-- US$70 Siemens CL55-- US$65 Siemens CT56-- US$30 Siemens M50-- US$35 Siemens M55-- US$120 Siemens MC60-- US$79 Siemens ME45-- US$50 Siemens S45-- US$60 Siemens SL42-- US$65 Siemens SL45i-- US$69 Siemens S55-- US$85 Siemens SL55-- US$125 ========================================= Nextel ========================================= Nextel i55sr-- US$65 Nextel i2000plus-- US$35 Nextel i58sr-- US$30 Nextel i530-- US$35 Nextel i205-- US$20 Nextel i305-- US$25 Nextel i35s-- US$29 Nextel i88-- US$30 Nextel i90-- US$59 Nextel i95cl-- US$70 Nextel i60c-- US$40 Nextel 6510TM-- US$110 Nextel i730-- US$85 Nextel i733-- US$95 Nextel i736-- US$105 Nextel i830-- US$115 Nextel i860-- US$125 Nextel i930-- US$140 =================================== Pda’s ================================== Hp ipaq pocket pc h4150 ========= $190 Asus my pal a716 ================= $175 Hp ipaq pocket pc h4350 ========= $185 Toshiba pocket pc e405 ========== $120 Sony clie peg-th55 ============== $155 Toshiba pocket pc e800 ========== $220 Palm one zire 72================== $120 Palm one tungsten e ============== $90 Palm one tungsten c ============== $140 Palm one zire 31 ================= $65 Palm trio 650=====================$240 ============================================= IPODS ============================================= Apple 4 GB ipod mini blue m9802ll/a---------------us$64.00 Apple 4 GB ipod mini pink m9804ll/a'-----------------us$64.00 Apple 4 GB ipod mini green m9806ll/a--------------us$64.00 Apple 6 GB ipod mini blue m9803ll/a'----------------us$68.00 Apple 6 GB ipod mini silver m9801ll/a-------------------us$68.00 Apple 20 GB ipod m9282ll/a--------------------------us$69.00 Apple 4 GB ipod mini pink m9435ll/a-----------------us$49.00 Apple 40 GB ipod photo------------------------------us$49.00 Apple 4 GB ipod nano----------------------------------us$69.00 Apple 2 GB ipod nano-------------------------------------'us$62.00 Apple 4 GB ipod mini silver m9160ll/a-------------------us$49.00 Apple 60 GB ipod photo m9830ll/a--------------------us$86.00 Apple 60 GB ipod photo---------------------------------'us$49.00 Apple 30 GB ipod photo m9829ll/a'-------------------us$73.00 New apple 60 GB video ipod--------------------------us$140.00 New apple 30 GB video ipod--------------------------us$120.00 ==================================================== PRICELIST FOR QTEK PHONES : ==================================================== Qtek 8100 Tri-Band Camera Music Unlocked GSM Phone White.....$125 QTEK 8300 GSM MOBILE SMARTPHONE.....$145 Qtek 8310 Unlocked Quadband GSM Phone....$165 Qtek 8500 Unlocked SmartPhone.....$155 Qtek 8600 Unlocked GSM SmartPhone....$225 Qtek 9000 3G Pocket PC Unlocked GSM Phone.....$320 Qtek 9100 Smartphone / Pocket PC Unlocked GSM Phone....$190 Qtek 9600 Unlocked GSM SmartPhone.....$280 Qtek G100 GPS PPC and Pharos Ostia GPS Software(US Maps)....$175 QTEK S200 GSM/GPRS Pocket PC Unlocked Quadband Phone.....$185 ========================================================= ALCATEL ========================================================= ALCATEL One Touch 501-- US$39 ALCATEL One Touch 311-- US$35 ALCATEL One Touch 511-- US$49 PANASONIC GD67-- US$49 PANASONIC GD92-- US$69 PANASONIC GD90-- US$69 SENDO X2 MUSIC PHONE:----------$96 HTC FARADAY-2100/2125:--------$300 SANYO MM-7500:-------------------$180 LG VX-8100---------------------------$215 PALMONE UNLOCKS TREO 650:---$140 TREO 650:-----------------------------$170 TREO 600:----------------------------$170 PALM TREO 650:---------------------$200 =============================== I-Mate ============================== I-Mate JAM 128MB Unlocked....$180 I-Mate JAMin Unlocked....$200 I-Mate JASJAR Unlocked....$290 I-Mate K-Jam Unlocked....$200 I-Mate Smartflip Unlocked....$190 I-Mate SP5 Unlocked....$130 I-Mate SP5m Unlocked....$120 ================================== Blackberry ================================== BlackBerry 8800 $180 Blackberry 8700v $170 Blackberry 8700r $165 Blackberry 8700g $160 Blackberry 8700c $155 Blackberry 8707g $150 Blackberry 8703e $145 Blackberry 8705g $140 We offer prompt shipping from our Warehouse factory,Typically the product will arrive within 2/3 Days Via Either Fedex/Ups Courier Sevices. NOTE: Shipping Charges are Base On Destination,So when Placing Order with Us Kindly Include your Location Such as State and Zipcode SO GET BACK TO US IF YOU QRE INTRESTD IN ANY OF OUR PRODUCT VIA ANY OF YOUR EMAIL BELOW Email address..STOPOVERSTORES_INC@HOTMAIL.COM Email address..STOPOVERSTORES_INC@YAHOO.COM Thanks and god bless you
sandra
FOR SALE/NOKIA N93i,D WADE SIDEKICK 3,NOKIA N95
