just took my engine out and the prop shaft dropped causing the thru hull bearing to break. The shaft dropped because the strut was also broken. So I am going to replace the packing gland, the bearing and the strut. I have not done this before. The shaft is out now and the hole plugged. Can anyone tell me in detail (or give me web info), on how I do this and where I get the parts I need. The boat is a 1979 Hunter 30. I am unfamiliar with the exact names of the parts I have to replace.
Also, I am guessing that I will have to put the shaft back in from the inside, since I do not want to remove the rudder. Am I on the right track? Any help would be educational and much appreciated, thanks
