I installed my Raritan Elegance head in early June and have been using it regularly ever since. I'm a liveaboard and am the only user. It's been wonderful up to two days ago, when I noticed that it had more water in the bowl than it normally has after a flush. When I checked the platform behind the head it was very wet. I dried it all off and looked for any leaking hoses but found that nothing appeared to be leaking.
I haven't had the problem with extra water in the bowl since then, but now whenever I do a normal flush, where it flushes and fills 3 times, enough water leaks out of the back of the toilet to completely wet a single, full-size section of paper towel. The discharge hose is dry, and I'm comfortable that nothing is coming from that. The freshwater inlet hose and connectors are also dry, so frankly I can't figure out where the leak is, but I'm pretty sure it's a freshwater leak. I'm still investigating.
My question is this: has anyone else had this problem with a Raritan macerating head? If so, what is wrong? If not, should I contact Raritan at this point?
Thanks in advance
Denise in Portland, Oregon
Thanks in advance
