Problem in the Bow. Need to Empty but No Drain.
Got a nearby pawn shop? I guarantee that they will have a used shop vac there for 1/3 the price of new.
Right on!!!!... or Craig's List. Can't tell you how many tools I've "borrowed" on Craigs List. Buy it cheap, use it, relist it.
I call craig's list the community tool shed.
When I refurbished my keel.... I found an engine hoist for $75. Had to put a new jack on it for $40. Sold it for $125 when I was done and made $15 profit.
I just did a search on my local Craig's List for Shop Vac and got 81 hits... and I don't live near a big city.
Jan 7, 2011
6,013
Oday 322 East Chicago, IN
I just purchased an '88 O'Day 272LE. The blackwater tank is in the bow under the v-berth. The hatch above the berth has apparently been leaking since I purchased it.
My issue is, there's nasty water in the front under the berth and while I'm trying to figure out where it's coming from, I need to get it out. It's not connected to the bilge (would've been too easy).
Are there any tricks to getting it out? There's not really room to get a pump down in there, and even if I did, it would only get most of it out. I'd like to get it all out and scrub it clean. Also, I think it's too low to siphon.
Any help is much appreciated.
It may be that the forward compartment was designed to be water-tight in case of a collision or other damage to the bow. My H280 front compartment (fresh water tank and water heater on my boat) does not drain into the bilge. I assumed it was for safety in case of a collision. But it is a pain to get rid of the water in and around the water heater when I drain it for the winter.....but my old shop vac does the trick just fine. I also use it to get the bilge really dry after cleaning it. I keep it in my dock box do it is always close by,
Good luck cleaning things up.
Greg
