Prevent engine starting in gear
SFS
Aug 18, 2015
2,088
Currently Boatless Okinawa
My Hurth tranny info has a warning about letting the prop spin while the boat is moving under sail. Both reverse and forward are ok. When I start the engine, I just crack the throttle open a bit so if I forgot and left it in forward it will not be taking off at any clip and if I left it in reverse, the forward momentum of the boat dominates and the motor stalls. Now I do have a small engine, but this whole topic has not been an issue for me. Ask me in 5 years when I am 80. ;)
If you can remember to "crack the throttle" before starting, why not just check the transmission lever at the same time?
Jul 5, 2011
751
Oday 28 Madison, CT
My bad. I got that mixed up. You are 100% correct. Forward is a no-no. Neutral and reverse fine. I go to reverse generally. Always shut down in neutral, never in gear but yes, always check for neutral before starting just like with my stick shift car.
