Pressure Washers
84
Beneteau 473 Rock Hall, MD
Time is coming to get the boat back in the water here in Rock Hall, MD. Got my cover off and starting the clean up process. Some significant work needs to be done to clean up the decks, etc. It appears that the sea gull population on the bay has been coverted by the Taliban and they are taking hostile action on my decks!
I was considering getting a pressure washer to help with the initial cleaning and then to use periodically duriong the season to help keep topside clean. We are marina sailors for now. So out on the weekends and back in during the week.
Anyone have any experience with pressure washers. Brand / Model recommendations that work?
Any help would be great ....
Glenn
Tejas
Dec 15, 2010
164
Beneteau First 36.7 Lake Travis
You might want to beware of how you use a pressure washer. A pressure washer can eat-up teak quite rapidly for example. Essentially -- use with discretion I think.
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
It depends some on whether you have shore power. We do at our marina and I have used a Karcher electric and it did fine. A word of caution, use the least pressure that will do the job and avoid spraying directly on your fittings. High water pressure can remove the sealant. Because of that, I don't use one regularly.
As much as I love scrubbing with a brush and soapy water I have to think that a power washer will be an enviromentally preferrable way to lean a deck than soap and water - however biodegradable
Oct 14, 2005
2,191
Karcher...
Glenn, I use the smallest one Karcher makes, yesterday in fact. It's small size makes it easy to manuever on deck and carry about without fear of a hernia.
Soapy solution applied with a deck brush as usual, with lots of elbow action. Pressure washer used to rinse off soap and any residue. Adjustable setting on the most forceful, but never applied less than a foot of the surface. Caution mentioned about too much pressure removing caulking is quite true from past experience.
Pressure washer is great when on the hard for getting up under the rub rails (particularly on the H34's overhanging one) to dislodge all the spider nests and survivors of the mild winter. First shot of spray and the hull side looked like a miniture lesson in rock face repelling.
Also makes removing FSR easy after applying it along the waterline and on the bow "mustache".
Dec 2, 1999
15,184
Pressure washers are a great way to clean the bird poo off the boat.
Be aware of the aformentioned interfaces bedded hardware & teak. These units will also do a good job of removing oxidation (not sure if this is environmentally friendly).
Just use it with discretion and warnings and you should be okay.
caguy
Sep 22, 2006
4,004
Go for it! I love mine. I have a 2500 psi gas driven washer. I has a 5.5 hp Honda motor. I lucked out at Home Depot. I bought it for $125. It was marked down about $100 because the box was opened. Someone bought it and returned it. Everything looked like it was there and the floor man reassured me that if it did not work I could return it. When I got it home I unpacked the box and found about $100 worth of accessories.
I bought it originally to wash my truck but found it works great on the boat. Like you I was hesitant to use it on the gel coat. I use the 15* spray tip and it cleans everything. I used it to strip the loose paint off the trailer and it remove all of the paint except the primer. I have used it to strip varnish off from teak after retreating with paint remover.
I especially have found it useful at the marina to wash the Cat 27. It has a 25 ft hose so I can do the whole boat without moving it. Our marina has coin operated wash stations that only take 1 quarter for 1 minute of water. I am able to fill up one of their 50 gallon water barrel that they use for trash cans. They put a liner in them so they stay clean. I can fill one up for 50 cents (takes it right to the brim. I take it back to my boat space in Mast-up on the tailgate. The first time I used an 12v water pump to supply water to the washer. The second time I used a sump pump laying around the garage to pump the water much easier to set up. It only uses about 2 gallons/minute so the barrel lasts about 1/2 hour.
I have a honda, purchased it at Lowes. I LOVE IT! Once you own a pressure washer, you find all kinds of uses for it. It is frankly the best tool I have ever purchased. I wash my boats, cars, patio house etc. several times each year and they do a great job. My honda is now 6 years old, and the only maintenance I've had to do is change the oil and spark plug each season. Starts on second pull every time (first with the choke then she starts).
Don't use the red nozzle unless you want to etch something ... and even the green one will take the skin off of your foot if you are wearing flip flops while using it.
May 4, 2005
4,062
be VERY careful of the high pressure washers on the gelkote. it can pit the gelkote if you blast it.
-not unlike blisters, the water goes into and past the gelkote, and can dislodge it.
Ends up looking like thousands of micro dots, that REALLY hold dirt.
bleach and sun > pressure washer
Gunni
Mar 16, 2010
5,937
There is a significant risk of an "injection injury" with these tools. More so if you are using a soap siphon attachment. A pressure washer can pierce your skin and inject nasty stuff right into your bloodstream. Feet are a prime injury, followed by the hand (silly user points nozzle at hand to see how powerful the spray may be).
Jun 6, 2006
6,990
Thanks Gunni
I'll remember to not try and bursh my teeth with it.
Personally I think you nailed it with "Silly user......" Natural selection at it's finest.
or as John Wayne said; "Life is tough, it is toughter if you're stupid"
and there is no cure for stupid
241
Hunter 410 Charlevoix, MI
Also.... Be careful decals and vinyl lettering and graphics. Pw is best way to remove vinyl! Also be careful of lines and canvas. You can cut through a line - fast and canvas is no match for it. Regarding pressure injection injuries.. These apply to anything driven by compressors... I lost a finger to gangrene caused by a high pressure injection accident. I was fortunate...originally docs said I would lose my hand. Be sure to wear real shoes with socks when working worth one of these things.
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
Unfortunately, it usually won't remove all of the decals if they have been on for a while.. only random chunks, which then requires further work to completely remove :)
Cheers,
Brad
PS: Yes, been there, done that!
Dec 2, 1999
15,184
Actually the best tool I found for decal removal is a wall paper steamer. Then next best is the "eraser" that is used on a power drill.
-na -NA Anywhere USA
After five years of power washing a boat, a customer brought his boat in with the gel coat pitted not knowing what he had done wrong. As many have indicated, it is the pressure setting and of course nozzle. If you insist on using a water pressure, then turn the pressure way down using a wide spray nozzle. Boat yards love repairing the boats from use of high pressue equipment that owners used on their boats.
Crazy Dave
May 24, 2004
7,215
CC 30 South Florida
I like those small electric units with a pressure that does not exceed 1200 psi. I use the tip which gives a wide spray and control the pressure by getting it closer or farther away
Mar 26, 2011
3,970
Corsair F-24 MK I Deale, MD
I think some guys just love powe rtools. Warn as much as you want that it's the wrong tool for the job, they will still chose the power tool.
I too have seen damage done to everything a power washer can be used on. As far I I'm concerned they are for inside oil tanks and process equipment, concrete, and little else.
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
Pressure Washer Works Like a Sander
Pressure washers do a great job of cleaning bird and spider crap. They also make quick work of destroying teak, dislodging the adhesive under deck fittings where water will find its way below and best of all, will put micro-pits on gelcoat. Later on you will appreciate the pressure washer as it washes all of the dirt and mold that is held in those micro-pits.
Get the one that has the highest pressure and you can even use it to create cool patterns or even engrave your name on the side of the hull.
Of course I'm kidding however I would never use a pressure washer on a boat because it does more damage (over the long term). I would invest in a light weight fabric tent to put over the boat when it's not in use.
Are you guys serious? This thread kind of reminds me of the PDF thread we had last week... Yes! you can be an idiot with a pressure washer... or you can use the green nozzle, not get too close to the boat and do a great job of washing your boat quickly... and without all of the doom and gloom predictions we are hearing here. Maybe I should lanyard an EPIRB to my pressure washer and wear a safety harness when cutting my grass :D
Its a tool! Use it smartly and it makes your life better.
Lets start a thread on table saws next.
caguy
Sep 22, 2006
4,004
Perhaps a Mainesail Myth Buster demontration is in order.
Thanks rgranger, Finally a voice of reason.
How about it MaineSail?
