Malcolm
While doing a routine check on the engine bay last weekend I noticed a few patches of black rubber dust/particles the engine pan and on the block. Closer inspection showed the black rubber hoses for the heat exchanger in the hot water service were chaffing on one of the injectors and where they pass through the bulk head. I caught the problem in time but there was noticeable damage to the hoses and this could be aproblem if not rectified. Might be worth a look if you have a 310.I also decided to fit the emergency tiller just to see how it fitted. It didn't!!! Another job for next weekend to clean up the top of the rudder post so the emergency tiller tube will fit.I'm sure others have found these and similar potential problems but I just thought I would share them as I would be grateful to hear of other peoples similar issues. regardsmalcolm
