Potable Water
18
Hunter 28 Henando Beach Yacht Club
Just purchased my first sailboat, a 1992, 28' Hunter. Thinking the water has been in the 2 tanks a long time. I need your input on how to keep the the tanks fresh so the water remains potable, OR perhaps that water is no for drinking at all, just dishes, etc.
Thanks for your input.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
No Drinking
We only use the tank water for showering and washing dishes,I would flush it out with fresh water and add either table spoon of bleach or a water sanitizer of some type and this way you still keep it fresh and clean for any thing but drinking to play safe.
Nick
Nov 6, 2006
10,246
Peggy Hall has a book about such things. Here is a post from a while back.. This lady knows her stuff:
If you're only cleaning the tank, not the plumbing too...
Top
you're only doing half the job. Although most people think only in terms of the tank, the plumbing is actually the source of most foul water, because the molds, mildew, fungi and bacteria which cause it thrive in damp dark places, not under water. Many people—and even some boat manufacturers—believe that keeping the tanks empty reduce the problem, but an empty water tank only provides another damp dark home for those “critters.” To do it right, use a solution of 1 quart bleach/50 gal water....fill the tank, then turn on every faucet on the boat. When the water coming out smells strongly of bleach, turn off all the faucets, but leave the pump on to keep the system pressurized so the solution stays in the lines. Leave it in the system for at least 3 hours, but no longer than 24 hours. Then drain the tank through every faucet on the boat. Fill the tank again with clean water...drain again through every faucet. To remove excess chlorine taste or odor which might remain, prepare a solution of one quart white vinegar/five gallons water and allow this solution to agitate in tank for several days. Drain through every faucet, then flush the system with clean fresh water. This will also get rid of any anti-freeze taste/smell. People have expressed concern about using this method to recommission aluminum tanks. While bleach (chlorine) IS corrosive, it’s effects are are cumulative. So the effect of an annual or semi-annual "shock treatment" is negligible compared to the cumulative effect of holding chlorinated city water in the tank for years. Nevertheless, it's a good idea to mix the total amount of bleach in a few gallons of water before putting it into a metal tank. Be sure to turn off the water heater at the breaker before beginning the recommissioning...do not turn it on again until recommissioning is complete. An annual or semi-annual recommissioning according to the above directions is all that should be necessary to keep your water tasting and smelling as good as anything that comes out of any faucet on land. If you need to improve on that, install a water filter. Just remember that a filter is not a substitute for cleaning out the system, and that filters require regular inspection and cleaning or replacement. To keep the water system cleaner longer, use your fresh water...keep water flowing through system. The molds, fungi, and bacteria only start to grow in hoses that aren't being used. Before filling the tank each time, always let the dock water run for at least 15 minutes first...the same critters that like the lines on your boat LOVE the dock supply line and your hose that sit in the warm sun, and you certainly don't want to transfer water that's been sitting in the dock supply line to your boat's system. So let the water run long enough to flush out all the water that's been standing in them so that what goes into your boat is coming straight from the water main.
Dec 2, 1999
15,184
We have always used water from our tanks for cooking, cleaning and bathing. Follow the instructions that Kloudie posted and you should be fine. We normally re-fill our tanks every couple of weeks during the season and have never had a problem. Of course it depends on your water source, which can be suspect too.
Dec 14, 2003
1,450
Like Steve, after commissioning the system properly I use water from the tanks for everything. Bottled water is kept in the fridge however as it is easier to get cold than adding ice to tank water. And for splashing a little in my scotch ;)
Apr 27, 2013
18
Thanks to all for your proompt input. I now 100 times more about this than I did a couple of hours ago, and this information will serve me well.
Mar 3, 2003
710
Hunter 356 Grand Rivers
Follow Peggy's procedure. We do annually and use our water for everything and have never had a problem. If it tastes a little funny, then just decommission. In Florida, you may need to do it more than once a year.
May 13, 2013
21
Hunter 336 Windsor
well..
i wouldn't even use the water to wash my hands.. here's what i found.
mineral spirits to clean the butyl; bleach the hell out of the tank.. and on order.. a clear plexiglass replacement for viewing and easy access..
quick and easy; relatively painless..
i don't understand the design; as it seems permanant and not intended for dismantling and cleaning.
Pumice
Mar 10, 2013
3
Hunter 28 Greers Ferry Lake, AR
water tank capacity?? gauge?
Little late in the comment DeaconWayne! I meant REcommission, not decommission. Sorry- makes a big difference in what you would do!
What is the capacity of the freshwater tanks in the 1990 H28?
Is there a gauge?
Is there a relief/overflow? I read about one in the manual but cannot find it.
Thanks
Apr 27, 2013
18
Thanks for the reply.
1-30gal tank.
Haven't looked at it so don't know about overflow and don't think there is a guage. These are all the things I will get into when time permits.
May 13, 2013
21
Hunter 336 Windsor
after a relatively quick and painless clean up job;
polycarbonate sheet, the same screws used for the previous wood and laminate;
some fantastic butyl tape bought at a local roofing shop (pliable, waterproof, sticky like stick tac not like silicone and long life)
budget job for a nice finished product..
re previous post;
no gauge but its clear plastic and can look through hatch while filling..
there is no overflow valve but i suspect your air vent may act somewhat as an overflow?
any questions feel free to ask..
1,509
Boatless ! 26 Ottawa, Ontario
I installed a 6" round access deck plate( http://www.westmarine.com/webapp/wc...&subdeptNum=50688&classNum=50690#.UepzV42siSo ) in the top of water tank in our previous boat, and intend to do the same on our current vessel. The clear cover allows easy inspection of the tank and makes cleaning the tank out quite easy. I used "food grade" silicone rubber caulking to seal the outer ring to the plastic tank. We don't drink the water in the holding tank but it is used for washing, brushing teeth etc. some caulking materials can contain some nasty chemicals.
Bob
