Reinhold Fussle
Help! I have a problem with the water pumps both in the head and the galley. When starting to pumb I get about a half a cup of water out of the spigot and then it stops. The vent line is clear and the problem is the same with the filler cap of. I replaced one of the pumps with the same results. This fall when I drained the tank in the bow I did it by disconecting the hose under the sink and pumping (sucking) the water out through the line. It took a long time and the water just didn't flow out freely. When checking for obstructions in the line by blowing into it there was no resistance! Any and all ideas are apreciated!
