So--any opinions or recommendations out there for a portable, compact, jump-starter battery that will crank a 3-cylinder (1.5 liter) Yanmar 3JH3E? Say, VicTsing 400 A or other?
That is odd, your house battery should have all the voltage and amperage you need to start and run the refrigeration. I would get to the bottom of that because having to leave your starter battery connected to the house circuit is where you risk taking it down to a no-start situation. My starter battery sits unused, and disconnected most all the time, it is only there to perform what you are looking to do with a jump-start pack.The house batteries alone will not start the compressor even if the batteries are brand new and fully charged. The house batteries alone will run the fridge compressor after it has kicked on.
So, it seems that disconnecting dead batteries and hooking the jump pack directly to the cables to the starter may get the engine started easier than connecting it directly,to the dead batteries. That was my experience as well. I suppose opening the compression levers to get the engine turning over, then closing them would also help.For a car they are marginal at best for a boat with a diesel and big dead batteries, save your money and get an AGM based jump pack with a 20Ah to 30Ah battery...
Most of these packs rely on your battery not being completely dead. They will actually start a motor without the batteries in place easier so be wary of those shady & misleading videos. The reason for this is the jump pack is not wasting precious starting current/capacity charging your dead battery first, reaching voltage equilibrium, before you hit the key. Believe it or not removing the dead battery from the equation can actually make it easier on the jump pack so don't be fooled by that sort of bovine dung....
I find it continuously fascinating that skippers will LUG these POSs around, in spite of Maine Sail's remarkably cogent presentation.Bottom line: Design your on-board DC system correctly with proper isolation and redundancy, and there is no need to carry any jump pack.
KG, I know you know your stuff. I had this problem last August. I called it, for many years, my "Fridge Follies."!!!Strange, but the compressor on the fridge evidently will not come on unless the starter battery is connected.
It rarely is. I did ALL the troubleshooting from my A/B manual and Kollmann's website. 99% of fridge issues, as Richard says, are electrical. And older modules fail well before the compressors do. I traced it to the module.Perhaps the compressor on the fridge is faulty.![]()
KG, FYI, I wrote this up in a separate thread last August. Do a search on RParts and you'll find all the contact info, too.contact RParts in Santa Cruz. They have a module for my 30 years old Adler Barbour Cold Machine, took me all of 3 hours to install it. $230 including s/h.
The only dead battery I've experienced where I could not start the engine in nearly 30 yr of boating was on a chartered boat--a Cape Dory 28, way back at the beginning in FL. Also around the time I still had anchors dragging for no apparent reason!! I sailed the thing most of the way home, beating, until I finally called the charter company on my hand-held VHF (a good reason to have one) to come and jump me.4 Trojan T-105 for house and a group 31 dedicated to start. I have the same engine, 3JH3E and have never had an issue in 12 years with not being able to start my engine.
