Replacement Ports
Howard,The size for your ports in the main cabin are 7x15. The ones in the head and v-berth are 5x12. I own an 83 model H27 and have already been through the process. I replaced mine with bronze ports from New Found Metals.(www.newfoundmetals.com) Although more expensive than the plastic replacements from Bomar, the quality is worth the money if you can swing it. Nobody except bomar has a 7x15 portlight. The one I purchased is a 7x14. It was more work to install, but is possible. You will find the 5x12 is a common size with a few different companies. Check out JSI sailnet for the Bomar replacements.(www.sailnet.com) They had the best prices for these ports last time I checked. Tell the salesman you need the Bomar replacement for Grey Industries ports. They also have replacement lenses, knobs,gaskets and other parts. I bought some lenses before buying new ports. I broke the frame on one portlight while driving out the pin that holds the lens in! That is one of the reasons I bought the bronze metal ports. If you would like, you can contact me at h27@gate.net and I'll help in any way I can. Good luck, Howard Sherman SV Escape
