Polyflex engine mounts
5
Hunter 340 Victoria
I have a hunter 340 with the original Yanmar 3GM30F and the original Yanmar Mounts. The engine shakes a lot. I have thought about replacing the Polyflex engine mounts. Has anyone done this and if so how has it been? How is the vibration and noise now?
Thanks Chris
Dec 2, 1999
15,184
I would not suggest doing this unless you speak with an "authorized" Yanmar dealer. Yanmars use different mount for the forward & aft motor mounts.
Rick D
Jun 14, 2008
7,206
And side to side too...
The distributor's rep said, at least on my engine, each mount was unique.
Jun 4, 2004
834
Hunter 340 Forked River, NJ
I have the same boat and engine. Before investing in new mounts, I would check the shaft alignment and prop. I changed from the original two blade prop to a Campbell Sailor three blade and any noticeable vibrations I had have disappeared.
