Plummers putty
-na -NA Anywhere USA
This week I worked with Kermit on installation of the Hummingbird Piranha Max 175 fish finder with depth. The transducer sometimes referred to as a puck by some comes with instructions to attach to the underside or transom of the boat without any mention of shooting thru the hull. I called tech at Hummingbird and they said it could work shooting thru the hull. They suggested two part epoxy but that along with 5200 or as some would say Satans Glue would not be recommended by me in the event of removal.
the viable place of attachment is adjacent to the bilge area or pump/float switch on the stbd side. First you have to sand smooth as much down to the fibereglass although some gel is in the small void or curvature areas is ok. The question was to go either mineral bath, 4200 or using the plummers putty.
The key folks is to use a lot to make sure when emersing the puck or transducer into whatever you use, make sure there are no air voids as that will mess up the sending unit.
I said what the heck to use plummers putty. After sanding and cleaning with acetone to insure no water, I applied a rather large goop of plummers putty and emersed the puck into it and built it up around the puck to hold it in place pushing down close to the hull ensuring no air bubbles. Not only did it hold but easy to use and the puck worked like a charm with the readings. The plummers puty is cheap and thank you goes to Chris Patterson for the suggestion. It made me a believer. Sorry Kermit about beating you to the punch.
Beribbit
Kermit
Jul 31, 2010
5,722
Check my post under Ask All Sailors titled Chris "Plumbers Putty" Patterson. You did NOT beat me to the punch!
Feb 20, 2011
8,062
Briefly, I thought that post might have been an obituary...
If I ever croak, then I will be up above waiting for all of you fine gents. No I an not talking about croaking like a frog.
Nutin against frogs or Mr. Kermit. You should know as you had to put up with me for two days. Poor mr. frog. You sir get an atta boy award for that one.
Feb 6, 1998
11,772
I have a customer that slapped a transducer into a toilet bowl wax ring back in the late 90's.. It is still working today.... Elegant, heck no, does it work? Apparently, if 16 years is considered a decent trail run..:D
But Plummers Putty is a lot cleaner and easier to install. I would suggest over the toilet ring plus it reminds me about the head or crapper as I call it.
Kermit
Jul 31, 2010
5,722
I promise to report back if it doesn't hold up. Shoot, I'll put a reminder on my phone to report back a year from now one way or the other.
May 8, 2013
27
Hunter 240 Indianapolis
I've used something similar in both my sailboat and kayaks for years with good success. It's called DUCK SEAL and can be found in the electrical isle at stores like Home Depot. It's used outside to weather seal electrical components. It is like a putty and comes in a bar form. It costs less than $5 per bar.
