I could do that but then I'd have to take power to starter from the other battery switch so I have an option as to which batteries to use for starting.Re the second 1-2-B switch.
What is the purpose of the short wire from the bus between the switch and the ACR doing for you? The ACR feeds into the reserve bank.
If you eliminate this wire, the second 1-2-B simply becomes the I/O switch we've been suggesting, per the wiring diagrams previously linked, and as suggested by Maine Sail. We recognize you already own the switch, but using it simply is a lot easier, although it will still require an on board wiring diagram and instructions.
