Please help with DC wiring
May 13, 2011
86
Catalina 30 Vancouver, BC
Re the second 1-2-B switch.
What is the purpose of the short wire from the bus between the switch and the ACR doing for you? The ACR feeds into the reserve bank.
If you eliminate this wire, the second 1-2-B simply becomes the I/O switch we've been suggesting, per the wiring diagrams previously linked, and as suggested by Maine Sail. We recognize you already own the switch, but using it simply is a lot easier, although it will still require an on board wiring diagram and instructions.
I could do that but then I'd have to take power to starter from the other battery switch so I have an option as to which batteries to use for starting.
May 13, 2011
86
On my diagram I show the ACR wired to the +bus, is this correct or should it go direct to battery post?
May 13, 2011
86
On the AC wiring what would you all suggest for wire gauge? I currently have all 3 bundle 14awg wire. Coincidently my AC isn't grounded to DC wire bus or anywhere else for that matter (oops!), going to the marina first thing in the morning. I also had an idea about making a set of jumper cables for that unseen emergency. I could utilize a pair of anderson power pole connectors, one side wired to position 2 of my engine starter switch (currently wired to be just an on/off switch) and the other end would be a 25 foot or so of 2/0 wire pair attached to battery clamps.
I've attached a cleaned up version of the diagram.
922
Canadian Sailcraft CS27 Victoria B.C.
Why vhf? So that if any catastrophe happens to the electrical system, as long as there is something left in the batteries the vhf will work.
May 13, 2011
86
Mar 2, 2008
406
Cal 25 mk II T-Bird Marina, West Vancouver
You should consider adding a Galvanic Isolator between the AC ground and the DC negative/ground connection. I had a nice Campbell Sailor propeller eaten away during three months of being plugged into shore power for a heater last winter.
Have you read Charlie Wing's Electrical Handbook? Reason I ask is that all of the issues you have brought up are answered either in the links provided or in his book, or both.
May 13, 2011
86
Not really a book kinda guy, and yes I've read most of the links provided. I ask questions to confirm what I read to make sure I understood right.
