The Catalina 30 has a similar setup. The rudder post just slides in a fiberglass tube. The two common methods of fixing this are to install shims and inject graphite epoxy filler. I went with the plastic shims. I was able to try different shims (a time consuming process) until I found one that I was happy with.
West Systems has an excellent article on using epoxy. While there are kits, you can buy graphite separately if you'd like to save some money.
Please post some pics of your rudder configuration
