Play in rudder
Nov 10, 2009
4
Bristol 35 Long Island Sound
Has anyone with either a Harbor 25 or Harbor 20 had to fix excessive play in the rudder. I understand that it might not have bearings and the shaft runs directly on the fiberglass. Any input would b appreciated
Nov 6, 2006
10,257
I am not familiar with that boat but typically the rudder shaft would run in plastic bushings that are pressed or sometimes glued in the fiberglass support. There will usually be a thrust bearing to take the vertical loads of the rudder. Nylon is not a good choice for the bushings because of swelling but stuff like Delrin and other engineered plastics can be fine. Ya might want to contact the Harbor 20 class association and see what others have done. good luck !
4,823
Catalina 30 MKIII Chicago
The Catalina 30 has a similar setup. The rudder post just slides in a fiberglass tube. The two common methods of fixing this are to install shims and inject graphite epoxy filler. I went with the plastic shims. I was able to try different shims (a time consuming process) until I found one that I was happy with.
West Systems has an excellent article on using epoxy. While there are kits, you can buy graphite separately if you'd like to save some money.
Please post some pics of your rudder configuration
Joe
Jun 1, 2004
8,361
I haven't researched your question, but I know that WD Schock is still in business and could possibly be a source for parts. Good luck. I remember when that boat was introduced and it became pretty popular with the flatwater day sailing crowd.
History | Harbor 20 Class Association
WD Schock - Sailboats, Sailboats, Harbor 20, Sail
  • Helpful
