You Guys were right, and I was wrong!
I put on the bow hardware today, and found that one of the screws spins, and the other 3 don't give me much confidence. They feel like a screw does when it's just about to let go, and start spinning.
I did not test them well enough when I took off the hardware, and now, I'm afraid to sail it. My plan was to sail it tomorrow, but the image of the mast, boom, sails, and a bunch of cables falling on me is giving me pause.
If I take a big screw driver, put it through the hole in the hardware, and lift up, the thing feels solid as can be. But I've been deceived before by my exuberance.
Does anyone know what is under that hardware? If you laughed, and said, "Yea, rotten wood", you'd probably be right.
My first idea is to take the hardware back off, and then cut the Luran so I can peel off a big piece of it to see what's what.
I need to sleep on this first. I'm not giving up, but I am feeling pretty stupid about now, so if anyone has an idea, let me know. I bet you thought you were done with me.
. Next season Ill remove a couple lag screws and inspect that same location. Nice to know its pretty simple once you get past the new 6" hole. Ill put a marine glove box there instead of an access panel.
