placement of fire extinquisers
3
catalina 309 quincy , mass
:confused:i just got our 309 in the water and to our home port . I am at a loss as to where to place the required fire extinquishers. Any sugestions?
Sep 29, 2008
1,981
Catalina 310 #185 Quantico
Five
I just had a USCG inspection and they mentioned I needed two. On the 310 (your mileage for the 309 will vary of course) are
V-Berth
Nav Station next to galley
Lazarrette
Head
The most likely places for fire are the galley and engine, so you want to have one between where you are most likely to be and those.
Aug 2, 2009
651
Catalina 315 Muskegon
We carry two. One's mounted on the wall under the companionway...just aft of the engine box. We took out the door to the aft cabin, along with the non-supporting wall next to the engine box. Used the fire extinguisher to hide a couple of the holes that were left behind from the wall removal. With or without the door and wall removal, this could be a good place to mount your extinguisher, as it's close to the galley.
Our other extinguisher is kept in the cockpit, in the small, aft, starboard locker. If there's a fire down below (sounds like Bob Seger?!?!) while I'm in the cockpit, I don't want to have to go below to get the extinguisher.
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
I have two - one mounted above the engine box in the step area, on the side bulhead adjacent to the galley (note you have to remove it to swing open the engine box). The other is on the starboard bulkhead in the forward cabin. I'm planning to mount one in a cockpit locker as well - just haven't gotten to it yet.
Jul 16, 2006
92
-Catalina C310 RNSYS
I just purchased a new fire extinguisher for the cockpit - I put it in the starboard aft locker (I have a tray over the water heater).
There is a second extinguisher in the cubby hole below the stove and a third forward in the 'owner's cabin'.
I have considered boring a small hole and installing an air tight cover in the bulkhead between the aft cabin and the engine compartment. In the event of a fire in the engine compartment, with a small CO2 extinguisher you could open the small cover and insert the nozzle and dump CO2 into the space without opening the engine access cover. Reseal the cover and monitor for heat. If this extinguished the fire you could monitor for re-ignition - if not, it would give you time to prepare to open the access hatch to attack the fire with a larger dry-chem extinguisher. All of this after making the appropriate pan pan or mayday comms.
Regards,
Chris
