Pipe threads
NYSail
Jan 6, 2006
3,145
Beneteau 423 Mt. Sinai, NY
So I replaced my hot water heater last season and added the threaded to hose barb fittings for the heat exchanger. Typically I do a couple wraps of Teflon tape and all good. However seems one of the fittings is leaking coolant from the threads. Will be redoing but just wanted to get feedback on what most use.... pipe dope, Teflon tape or both.
Thanks
Greg
Are the threads compatible, meaning are both straight or tapered? If the threads are mismatched, it will feel like the fittings are tight enough, but they will still leak especially under pressure.
Dec 2, 1997
8,949
- - LIttle Rock
Good point! Also...be careful NOT to OVER-tighten fittings in an attempt to prevent or stop a leak...that can actually make the leak worse and will crack a plastic female fitting.
--Peggie
NYSail
Jan 6, 2006
3,145
Yes... fittings are the same. Not over tightened. Saw a video where the guy uses Teflon tape putting into the groves only.
Anyway, guess I had just a bad wrap:banghead:.
Thanks
Greg
Mar 6, 2008
1,355
Assuming your threads match, I wrap 8 turns of pipe tape then wipe the above paste on both surfaces, then wait 10 minutes then put them together.
Likes: NYSail
Another option is using yellow teflon tape. This is designed for gas piping and is a bit thicker than regular white tape.
RoyS
Jun 3, 2012
1,742
The best plumber I know uses both on every joint.
Pipe Thread.. Pipe dope
