Pinrails on modern boats
Pops
Apr 11, 2004
154
- - Albemarle Sound
In preparing my boat for single handed cruising, I would like to install pinrails between the shrouds. I have seen some that were fabricated by a sailor (I think he sold them too) somewhere on the net. I have no idea where though. I was wondering if any one else had done this. It would seem to me that this might make dock line handling easier while docking (too often a fire drill in my experience). It would also look salty as heck. I have pieces of teak just laying around saying "Do this to me this winter".
27
Hunter 28 Burlington, ON
A Start
Here is a picture of what my friend Vince did on his Classic 37, Fortnight. It is as good a picture as I have, but maybe will give you the idea of how he managed it. As I recall, he made the pins from materials you find in the window hanging section of Loews, Home Depot etc.
This is how it looked after a winter in the Bahamas.
...It would seem to me that this might make dock line handling easier while docking (too often a fire drill in my experience).
Avoid the fire drills and learn to use midship spring lines.
HOPPING OFF THE BOAT IS UNNECESSARY
In the April 2009 issue of Latitude 38, Mark Johnston asked about dealing with aging knees and boat docking in “Senior Sailors and High Freeboard.” He expressed his concern about docking with a potential future bigger boat, noting “…it’s not so easy…for my wife and me to jump down to the dock with lines in our hands.” We’ve had our Catalina 34 for the past 10 years, with a C22 for two and a C25 for twelve before that, sailing all over the Bay, the Delta and up & down the coast. We employ what we believe is the most useful and safe technique for docking that still seems to be a mystery to most sailors. It’s called the midships spring line. Our older Catalina 34s did not come with a midships cleat, so we added one on each side at the forward end of the jib fairlead track. Many newer boats come with them. There really is no reason to ever have to jump off a boat to dock it properly. I recommend that Mark Google “midships springline” – there is a wealth of information available, one of which is: http://www.cruising.sailingcourse.com/docking.htm.
The maneuver is simple: attach the springline to the midships cleat, run it fair outside the lifelines, as you approach the dock loop the springline over the aft dock cleat and bring it back to the winch. Snug it up and keep the boat in low throttle forward and the boat will sidle right up to the dock, no jumping is EVER required. A friend developed an enhanced springline arrangement with a prefixed length of line with a hose holding a lower loop of line open to assure that it catches the cleat on the dock, so that no line needs to be returned to the winch.
I do a lot of single-handed sailing and have found this invaluable in docking in all conditions. I’m sure that once this “trick” is learned and mastered it can be used in a wide variety of docking situations with all manner of wind and currents.
It’s not only safer, it’s a sure knee and back saver. The only drawback is when docks don’t have cleats, but have those nutty rings or the wooden raised runners so prevalent in the Pacific Northwest. I think that’s one reason they invented grapnel hooks!
zeehag
Mar 26, 2009
3,198
pinrails and pins should be made of hard wood--the pins are turned on a lathe.....
Dec 9, 2006
694
Oday 22 Hickory, NC
There used to be a guy on the board that seems to have dissapeared...his name was something along the lines of SailorTony something...he made some that looked GREAT!
Anyone know his correct name so Merry Prankster can look up the post?
And sailortonybob as I called you...if you are still out there please email me...jackhartjr at aol dot com.
Jack
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
If any one knows the where abouts of Tony B it would be Franklin and I'm sure he'll chime in.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
if you dont find the fella you are looking for .....you may contact me and discuss the project....as i have a source for teak close by and i also have a full woodworking shop here in ga ........i also have the ability to turn your pins as well ....used to travel the woodworking show and demonstrate woodturning and have turned from seattle to orlando fl as well as melbourn australia
Beneteau 323 Annapolis MD
There's always nightsticks/billyclubs from the police supply store?
zeehag
Mar 26, 2009
3,198
they would be a bit larger in girth than the rails would like to contain LOL...but a goood idea....
