PEX vs Reinforced PVC
Ward H
Nov 7, 2011
3,843
I have original 1/2" reinforced PVC hose for the fresh water system on my 93 C30. I'll be scrubbing clean the two water tanks and thinking I might as well replace the 1/2" hose as most of it is looking pretty funky.
I read a little about PEX hose and wondering what the advantage was to using PEX vs reinforced PVC hose. Cost? Quality? Ease of Install?
Any suggestions?
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
The PVC hose is probably more "bendy" than PEX. Is there a complete line of fittings to work with like PEX?
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Not having read much about the application on a boat, I would think PEX would be the way to go..... In regards to the fittings, I know its not totally advisable for behind wall application, but based on the low pressure of our boat systems, the "Sharkbite" fittings they sell at HD might be nice as well.... again I have done no research on the topic, just my thoughts.
btw Beneteau used a PEX like piping for the hot / cold water lines that I am so far very happy with.
Greg
About 8 years ago, I replaced ALL of the copper pipe in my house with PEX.
Love it! You need to buy the crimping tool and it is not that cheap. But with the proper crimping tool PEX is fast, easy, reliable and versatile. Got to get the tool. So if you are only doing a small job, there may be better choices. You have to do the cost/benefit analysis.
Jul 7, 2004
8,542
+1
I have crimped all my own fittings at home and never had any problems. My Zurn set was just over $125
If you go with reinforced hose, avoid hose barbed connections to fixtures and use standard SS supply tubes. Like these https://amzn.to/2UpRsnl Much easier to make the connections.
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
I think the crimping tool is the way to go if you have a large number of fittings because the shark bite fittings are quite expensive. If you have just a few fittings, shark bite fittings will save you the expense of the crimping tool. I used the shark bite fittings and found on the suction side of the pump, the 1/2" PEX with a few 90 degree bends was a significant flow limitation. I changed the suction side out to 3/4" reinforced hose to solve that problem. I recommend PEX for the pressure side of the pump and hose for the suction side. If you need to snake the line through some bends on the suction side, you will do better with smooth curves rather than 90 degree bends and the PEX is not that flexible. Like David said, I used the flexible SS faucet connectors for connections to the pump and fixtures.
Likes: agprice22
Oct 26, 2008
6,432
Ward, what size are your tank fittings? I screwed up with the PEX installation at the tank when I did mine. I have a 3/4" male threaded fitting made on the tank, so when I put on 1/2" PEX I needed a reducer, and it was a significant reduction. Remember, the 1/2" PE is outside diameter. There is only about 3/8" I.D. - much less than the 1/2" hose. That's barely enough to pee through at the suction side. The pump has 1/2" fittings, so that's what suckered me into installing the 1/2" PEX originally. Combine that with 2 - 90 degree bends, and I barely had any water flow and the pump made an awful racket because it couldn't suck the water out of the tank. When I changed to 3/4" flexible hose, my problems went away. I only needed an adapter for the 3/4" hose to 1/2" faucet connection to lead into the pump.
BTW, on the pressure side, you can buy a flexible faucet connection to thread onto the pump fitting and it has shark bite connection on the other end for the PEX pressure plumbing system. It worked very well for easily connecting PEX to the pump with a removable and adjustable lead.
2,809
Ericson 29 Southport..
I completely replumbed a Cheoy Lee with PEX a couple of years ago. The owner specifically wanted the quick connects, (shark bite, whatever), and I wasn’t crazy about it. No problem though, if the owner has the money, I’ll cut it in half and make it ten feet longer if he wants. Anyway.....putting it in was one of the easiest jobs I’ve ever done, and I’ve plumbed a few boats. Snap together man.
The ends are a tad pricey, thereabouts of ten bucks apiece. He wanted the ability to take it apart and add or replace something down the road, (and after three years hes not added or replaced anything).
But it doesn’t leak. This is an ocean going boat, just returned from a pounding going to Bermuda and back. So I’m sold I guess. I wouldn’t hesitate to use it again..
Likes: rgranger
Jul 7, 2004
8,542
Sharkbites are magical. The same fitting can take PEX, copper, PVC and CPVC tubing. And with a simple tool will release the tubing without damage to fitting or tubing. You pay for it though. If the system design is stable, crimps are much cheaper.
May 7, 2012
1,633
Hunter e33 Maple Bay, BC
I have only had a couple of times where I needed to disconnect PEX fittings. It is one time I can honestly say "the job was easy" and really mean it.
HOWEVER, this summer we had a leak at the input to the transom shower box. Not a failure of the PEX fitting per se, but at the threads on the cold water inlet nipple. The angle of the rigid tubing was way to tight and put undue force on the connection, and resulted in a small leak. It was then that I realized that there was no way to isolate that line (or any other water line on the boat) except to turn off the domestic water pump and therefore remove pressure throughout the whole system. I now have several End Stop fittings that will allow a portion of the system to be isolated when needed..
May 20, 2016
3,015
It’s interesting early Catalina ran reenforced pvc from the tanks to the water pump. Then transitions to PEX. I might do pex for all and put in a tank manifold valve.
Rick D
Jun 14, 2008
7,207
HOWEVER, this summer we had a leak at the input to the transom shower box. Not a failure of the PEX fitting per se, but at the threads on the cold water inlet nipple. The angle of the rigid tubing was way to tight and put undue force on the connection, and resulted in a small leak. It was then that I realized that there was no way to isolate that line (or any other water line on the boat) except to turn off the domestic water pump and therefore remove pressure throughout the whole system. I now have several End Stop fittings that will allow a portion of the system to be isolated when needed..[/QUOTE]
As an aside, this is a common issue with 90's Hunters. While the angle may contribute to it, I think there is simply vibration and a mis-match of materials contributing to it. I had this happen (leakage) several times over the last 20 years, even replacing the shower assembly. The last time, I got uncomfortable with the cockpit shower not having a way to isolate the feed lines, so I purchased shut-off valves and placed them upstream from the shower. Now, I only turn on the cockpit shower when I am going to use it. Problem solved. See these valves available from ACE on-line: https://www.acehardware.com/departments/plumbing/valves/globe-valves/46854
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
PEX is great but make sure you keep it covered. It does not handle UV well at all. (According to my plumber that ran PEX throughout my house)
Oct 26, 2008
6,432
I would use this faucet connector to eliminate that hard connection that doesn't quite line up. It provides flexibility and a valve.
https://www.amazon.com/SharkBite-24...hvlocphy=&hvtargid=pla-4583520382301870&psc=1
If you are going to use PEX from the tank to the pump, I would use 3/4" PEX. At least it is greater than a true 1/2", not smaller. Also, I would avoid 90 degree bends and try to sweep the PEX through any turns that need to be made.
May 7, 2012
1,633
Great idea Scott, thanks. Athough many Hunters and other manufacturers use metric PEX (15mm) tubing vice the standard (1/2") I am sure there exists an equivalent item or items in metric.
Now that is something that is going on the project list. Thanks Scott. Now I have to consider whether to use standard sizes (3/4") from the tank to the pump or stick with metric (22mm). Hmmm. The latter would give me more volume/
Ward H
Nov 7, 2011
3,843
Scott, the hose barb off the tank valves is 1/2”. Not sure of the fitting size. Defender has a line called Sea Tech which sounds like PEX hose and Shark Bite fittings. Their hose chart shows the ID of the hose. Makes sense to up the size of the intake side.
PEX sounds like a good way to go.
May 20, 2016
3,015
Personally I like copper rings vs push connections, just seems more secure.
Les
Apr 26, 2015
663
S2 26 Mid On Trailer
It's always amazing how a certain way to do things morphs on these forums. I've made the first comment several times and turned the whole thread in my direction. I'm replacing the fresh water system in my 44 year old boat this month and went back and forth on PEX vs what has lasted for 44 years. I'm going to boil out the fittings and replace the hose with new and will be dead by the time it needs to be replaced. It's a substantial cost and effort savings that I will spend on beer :beer:. Nothing against PEX but why reinvent the wheel. KISS!
May 4, 2018
23
Catalina 25 SV Colorado
You don't actually need the tool to release the Sharkbite fittings, you can use a wrench and just push-in the fitting...its easy.
