I just read through the current downloadable Weems & Plath catalogue on Time & Weather instruments. It makes no distinction on any of it's time instruments as being a chronometer. All time pieces are labeled as clocks. Several of their collections are labeled as life time warranty.
While many of their time & weather instruments are made in Annapolis, some are listed as being assembled from globally supplied parts. Which I think means some Chinese stuff gets in there in a few collections. Collections that are made in Germany & Denmark are labeled as such while American made collections sport an american flag. The point being it behooves one to ask the origin if one doesn't want products with Chinese parts.
I think your best bet is to call them in Annapolis (eastern time) and tell them what's going on and they should be able to sort it out & resolve it for you. All of the wall mount clock mounting was non movable.
There was no discussion of allowing for movement.
If all of that doesn't set you on your path in correct time, you could always try NOT tacking via use of the iron jenny to see what the clock does OR you could sit at the dock & drink cocktails while you watch the clock to see what it does.
