Perkins overheating
Rob
We bought our boat last january and motered up from Annapolis to the Sassafrass,,,,,During our trip our belts came loose and we overheated....this caused some major damage. We had the head grinded and new head gaskets along with other work... water pump worked fine thru hull open....we had all the work done and the yard said it was working fine..... Last weekend...we took our first trip out since January..... a 2 hour cruise.......We ran the engine about an hour...evrything was fine...we found an anchorage dropped the hook had a late lunch....ww restarted and everything was fine for about 10 min..then the temp started to climb....normal 195..went past that to 220 then 280...we shut down... We ended up anchoring and spending the night.....Sunday Morn we wake up and try again...motor for about 20 min and the temp slowly climbed back up we shut down when it rose to just over 220.....sailed the rest of the way in until just before the pier..dropped sail and motored the remaining 10 min to slip....engine overheated and this time smoke in the cabin.........shut everything down. yard is now back on the boat. We have a 1985 perkins desiel........... Question is whats causing it?? Fouled prop?? blocked intake??,,bad sensor??..thermostate??.. We are leaving on a 2 week sail in mid June..would defintltly want solved. thanks for any and all help. Rob
Rick D
Jun 14, 2008
7,201
Need An Expert
It could be many things, but my bet would be that the head job went bad on you and you have a blown head gasket. That assumes you have fresh water cooling. Take a look at the oil to see if there is water in it. However, I'd start with the basics: belts, impellers, hoses, strainer, water passages and exhaust riser. You should get a competent mechanic to trouble shoot it for you. You don't have time for trial and error. Good luck, Rick D.
Rob
Thanks Rick
the mechanic is on board yesterday and today...we are also sending a diver down to check the prop and thru hull.....I agree, dont have alot of time......maybe doing fast vacation dot com..instead of 2 weeks on the boat...... thanks Rob
Rob
seagrass and feathers
in the water intake strainer......couldnt see the glass was so dirty.cleaned up and runs like a charm.10 hours engaged so far and no heating problems
